Old 06-11-2004, 10:52 PM   #1
MrRolla's Avatar
Trader Rating: 29 (100%+)
Default Help need with gearing for a 18turn
Hi guys,
I have had this Atlas 18 turn for a while and id like to use it. Id just like to know what gearing to use with out cooking the motor or brushes..
The car is a TA04 internal drive ratio is 2.13
Im running a 37/82 atm, will this be too high for the motor?
Dave
MrRolla is offline   Reply With Quote
Old 06-11-2004, 11:08 PM   #2
fatdoggy's Avatar
R/C Tech Charter Subscriber
Geez what is that, johnson 540 gearing? Don't run it with that gearing or you'll cook it. You running rubber or foam(if so how tall) ? Large track, small track?
fatdoggy is offline   Reply With Quote
Old 06-11-2004, 11:40 PM   #3
MrRolla's Avatar
LOL yeah that is the gearing i use for my 540
Umm its not actualy for a track im just going to have run at the local park
Im running rubber tyres 64mm diameter.
Dave
Old 06-12-2004, 01:25 AM   #4
fatdoggy's Avatar
Start with a gearing around 8.5 and go from there. You will probably have to add or loose pinion teeth depending on how the motor is running. Always check the motor two or three times through the first battery just to make sure it's ok.
Old 06-12-2004, 01:28 AM   #5
MrRolla's Avatar
Thanks or your help
Old 06-12-2004, 05:16 PM   #6
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
for indoor you can run a final ratio of 7.0 (an EP cars track)
for outdoor you can run 5.5~6.0 (asphalt track with 40meter straight)
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
tc3 gearing, 81/17, bad? ajg Electric On-Road 2 03-14-2004 08:52 AM
