LIPO's on 10th scale Touring? >
Old 06-11-2004, 09:55 PM
Default LIPO's on 10th scale Touring?
I have not found any good results, with pics, specs and brands used in Lipo cells test on 10th scale cars.
I have seen someone where state that they are bringing in 12,000mah cells.....huh?
So...i would like to run some tests on using some lipos in my T1R, equiped with a LRP F1 Pro Reverse (no motor limit) ESC, TO RUSH 11X2 motor.
I am thinking about running a 3800mah pack, 2s2p (1900mah) or something close to that...
THis will give me 7.4v, and the extra mah needed for the longer runtimes.
WHO OUT HERE HAS USED OR IS USING LIPO CELLS IN THEIR CARS? I would like to talk with you.
Thank you
atlrcracer is offline
Old 06-11-2004, 11:45 PM
Suspended
I use a Thunder Power 8000 mAh 7.4 volt lithium polymer...love it.
Check out http://www.tppacks.com
403forbidden is offline
Old 06-12-2004, 12:09 AM
Once the price comes down to a consumer friendly level & the mod motors evolve to withstand more, Lipo would be more popular
The Black Kat is offline
Old 06-12-2004, 06:31 AM
wow...that site does not have ANYTHING in stock.
Now...why do you run 8000mah packs when the reg. SC batteries are only 3300?
Old 06-12-2004, 06:45 AM
Suspended
thats a testiment to the popularity of Lipos
why do I run 8000 mAh?
....more capacity
Old 06-12-2004, 06:47 AM
yes...but there are tons of companies who carry lipos....but anyway...
Ok...so in your experience, would a 3XXXmah pack provide about the same runime as reg. 3000/3300mah NiMH SC cells? I just want to make sure the runtimes compared to MAH in NiMH and Lipos are about the same before i go pull the tigger on a pack...Money burning in my pocket!!!
Thank you
Old 06-12-2004, 06:52 AM
Suspended
hmmm...well I dunno about that because the only packs I have are the 8000 mAh and 7600 mAh packs
have you read this thread:
http://www.radiocontrolzone.com/foru...d.php?t=146287
it's pretty infomative
Old 06-12-2004, 06:55 AM
Ok...great article.
What runtimes are you getting?
What motor?
Old 06-12-2004, 06:58 AM
Suspended
I've used these packs with the Novak bl system. I can get 25 - 30 minutes...but I normally stop after 10 minutes to take a break lol.
I don't use the packs for stock racing though...I use gp3300 NIMH cells for that.
Old 06-12-2004, 07:06 AM
great....that is what i was looking for. Granted you are running the novak brushless motor/esc...which will yield you longer runtimes....
I am running the RUSH 11X2 motor....so I think my runtimes might be a bit under.
I am just looking for some good long runtime bashing (practice) packs.
Thank you
Old 06-12-2004, 07:14 AM
Suspended
cool...make sure to get a good lipo charger tho like an Astro FLight 109D
Old 06-12-2004, 07:56 AM
currently use a Triton charger....seems to work fine for me, for now.
Thanks for your help. I will hope to get the lipo project off the ground this week...i will post the updates.
