XRAY T1R diff questions
I have completed the assembly of me new T1R kit. And I have read here in the boards to leave the diff loose for a breakin period.
Also...the manual says to tighten the diffs so that they spin freely, but should be hard to turn when holding the output drives. To me....all of this is very vague. How hard is "hard to turn"? How loose is too loose? Currently i have them, I think TOO loose, where that when the car throttles up (in the house for testing purposes), the car takes a bit to actually to get moving. So..i guess I need to tighten them down a bit..but what is a good measurement to go by? Thank you |
You definately have the diffs too loose. If you listen closely you'll hear a screeching noise too. That's your diff balls going bye-bye :)
When re-building a diff here's the procedure I follow: 1. Assemble the diff per the instructions 2. When tightening the diff, tighten till the balls and diff rings just come into contact. At this point the diff gear can be spun easily while holding the outdrives. 3. Tighten the diff slightly maybe 1/8 of a turn. Hold the outdrives and spin the gear. It should be a little tougher to spin now. 4. Repeat step 3 till it's difficult to spin the gear while holding the outdrives but the diff action (spinning one outdrive while holding the gear) is smooth. This should get you close. After running a pack through the car, check the diff action and slippage. It may need to be tightened a bit. |
Re: XRAY T1R diff questions
Originally posted by atlrcracer So..i guess I need to tighten them down a bit..but what is a good measurement to go by? |
yep, ur diff is loose
just follow the instructions in the manual when u build the diff. then when its already assembled insert two 1.5mm allen wrenches on opposite outdrives, then try to spin the pulley. if you can spin it, u need to tighten the diff a bit, do this a little at a time till you find it hard to turn the pulley, then try it on the tracks and adjust as needed. |
Originally posted by atlrcracer I have completed the assembly of me new T1R kit. And I have read here in the boards to leave the diff loose for a breakin period. Also...the manual says to tighten the diffs so that they spin freely, but should be hard to turn when holding the output drives. To me....all of this is very vague. How hard is "hard to turn"? How loose is too loose? Currently i have them, I think TOO loose, where that when the car throttles up (in the house for testing purposes), the car takes a bit to actually to get moving. So..i guess I need to tighten them down a bit..but what is a good measurement to go by? Thank you |
Well...all is good now.
I used my heat gun to overome the shock ball end installation. I found an extra E-clip on the "extra parts" bag, which to me, should have been noted somewhere in the BEGINING of the instructions. I also found the setup book VERY HELPFUL on getting the diffs set correctly. I adjusted the toe in as well..... My fukayama cells arrived today and my ESC has been set! Tomorrow will be is 1st test drive. Anyone have any "break in" procedures to follow? Thanks |
Originally posted by atlrcracer Well...all is good now. I used my heat gun to overome the shock ball end installation. I found an extra E-clip on the "extra parts" bag, which to me, should have been noted somewhere in the BEGINING of the instructions. I also found the setup book VERY HELPFUL on getting the diffs set correctly. I adjusted the toe in as well..... My fukayama cells arrived today and my ESC has been set! Tomorrow will be is 1st test drive. Anyone have any "break in" procedures to follow? Thanks |
Re: Re: XRAY T1R diff questions
For me, I never seen a better instruction manual than the Xray. Unless you start giving out figures/numbers, all descriptive instruction are vague or interpret differently. Dose that means they have to give you torque figures? If you are not familier with setting up diffs, I guess the best bet is ask someone with experience on the track.
Just my 2 cent... |
