Old 06-09-2004, 06:39 PM   #1
Default Stock set up verse Mod set up
I currently have a stock set up that I am very comfortable with and have been doing good with. I just picked up a second car and won't to try Mod racing as well. (Electric tc3 running on rubber tires on asphault). Now I have been told I can not run my stock set up with a Mod motor...
Can some explain to me why?
Smalls is offline   Reply With Quote
Old 06-09-2004, 06:58 PM   #2
prodrive's Avatar
Default depends.....
it depends on how you drive. i have two trf 414 and i set it up differently. one is surikarn's south africa and the othe is surikan's hongkong set up. one is aggressive that the other and i use different motor on each of them.the less aggressive is easier to handle so i used stock motor because stock motors are punchy compare to 8 turn doubles. so since stock motors have high torque, the car is still easy to handle, whereas the other one with more aggressive steering is to compensate the smooth driving of modified
prodrive is offline   Reply With Quote
Old 06-09-2004, 07:18 PM   #3
Mike Haynes's Avatar
Smalls, depending on your current setup, track, and driving style, you will most likely have a problem with not enough steering. For mod i like the same spring all around with a rear sway bar (on the tc3). PM me if you want a decent mod starting point for the type of tracks in the new england area. It works extremely well at rc madness.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 06-09-2004, 08:06 PM   #4
Here is the setup. Hope it helps you.
Old 06-09-2004, 11:35 PM   #5
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Default setups
well from wat ive learned if u take a mod setup and put it on a stock car. either ur car should b dialed r very close. thats wat i did and my car is hooking up. but i race carpet wit foams. but i think ts pretty much teh same maybe r maybe not. just tellin u wat i did and it worked 4 me.
crACkeD ChaSsiS is offline   Reply With Quote
Old 06-10-2004, 03:09 AM   #6
Cole Trickle's Avatar
From my experience, stock motors have way more drag brake in them. So with a stock motor, you'll have more braking, meaning the weight transfers more/faster to the front, resulting in more steering, compared to a (mod) motor with less braking.
So I would agree, that with mod, you need a more aggressive setup with a mod motor. A workaround could be to dial in some drag brake in the ESC, if your ESC have that feature.
Torque? It's a while since I last tried a mod motor. It was a 18x4, which was quite torqy, so I didnt notice any problems here. But as said, it's some time ago, so I might remember wrong.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 06-10-2004, 07:27 AM   #7
prodrive's Avatar
well its different when you are using 8 turn mods, smooth running is needed so you can also conserve battery. when you push the th trigger full on, so much is sucked from your battery that you will lose your punch toward the last 2 minutes of the race. braking should be kept to a minimum. spooling up on mod motor also draws amps
Old 06-10-2004, 01:55 PM   #8
smalls,wot i normally do is if iam running stock ill just use my mod set up on it.
maybe increase front droop about half mm bc theres less weight going to the back in stock.
to go from stock set up to mod it depends how good ur stock set up is.
id be very surprised if your stock set up works good in mod to.
normally mod set ups are a bit stiffer because of more power.
also the set-up will have to be better and you as a driver would have to drive more consistant,which is harder in mod then stock.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
4 stock motors for trade 3 EXPRESS MOTORSPORTS,TEAM STOCK FANTOM speedemall R/C Items: For Sale/Trade 0 04-25-2006 06:14 PM
FS stock mini t receiver, esc, and radio, plus a modded hs81 that works with stock t to the maxx2 R/C Items: For Sale/Trade 0 01-16-2006 02:38 PM
8 brand new trinity stock motors paradox blue endbell#2104 & new monster stock #2140 jason cheng R/C Items: For Sale/Trade 11 05-08-2003 06:33 PM
