Esc Capacitors
Old 01-06-2004, 05:57 PM
  #121
rc-zombies's Avatar
Default Re: 50v capasitor
Originally posted by Leester
I was looking on the Panasoninc capasitor website with a 50 volt capasitor. Would that work on a Novak GT7? Let me know!
-Lee
10v is all you need...
there's some on ebay for $9.99 for 2 10v 10,000uf capacitor that is perfect for the GT7 and others.
rc-zombies is offline
Old 01-06-2004, 06:11 PM
  #122
Leester's Avatar
Trader Rating: 22 (96%+)
Would 50volt just fry the speed control?
Don't worry RC zombie I am no rookie to RC racing I'm just looking for something to get insanely amounts of power out of my TB evolution 3 I know how to tune a motor and drive a rc car
If I can't get 50V in the car could I go above 10V?
please give me as much information on these capsitors as you can
I will need all the help I can get
thank you!
Leester is offline
Old 01-14-2004, 02:50 AM
  #123
rough512's Avatar
thank you!
Hi,
It doesn't matter what voltage rating you install on your ESC as long as you don't use one whose rating is below the available battery voltage (7.2V).
It looks to me like you're under the impression that installing a 50v cap will give you 50V for your motor. Your capacitor will only charge up to the actual available voltage--that of your battery. If you want insane power on your car, go Brushless....
rough512 is offline
Old 01-14-2004, 03:26 AM
  #124
Interesting, say what happens with I have a 50V cap, I charge it up first using whatever means, then put it onto the ESC. Now whats gonna happen? Insane punch?? How long is that gonna last?
lawndoggie is offline
Old 01-14-2004, 04:17 AM
  #125
rough512's Avatar
assuming that the capacitor does not get disharged during installation, You will only get a 50V spike lasting a few miniseconds then you will be back on your battery voltage... but I really doubt this since you will be installing it in parallel to the battery. Once you connect the battery, your Capacitor is back to around 7.2V-the battery voltage..
rough512 is offline
Old 01-14-2004, 03:38 PM
  #126
Leester's Avatar
Thanks guys for all the help I'm going to be looking into this alot
By the way Rough512 I actally do run brushless and I won it a few times, also i just won the stock sedan class in the US novak touring car race this year it was pretty cool. thanks for the help!
Lee
Leester is offline
Old 01-14-2004, 06:37 PM
  #127
Registered User
Calvin Ng's Avatar
i thought the higher the voltage the less punch
i had a 16v and switched to a 25v and i felt a diffrent
lower voltage the better
higher the uf the punchier
correct me if im wrong..... this is how i remembered it
Calvin Ng is offline
Old 01-14-2004, 10:58 PM
  #128
xray racer's Avatar
Trader Rating: 22 (100%+)
hey everyone
i just bought an lrp quantum worlds kit for my quantum comp.
it comes with one large and one small power cap
which one do i use for stock racing to give me the best punch out of corners???
i know nothing bout all the tech side of things i just know there is a big and a small one and im just looking for one to give me lotsa punch
btw, i have punch setting on my quantum @ level 5, or full, is there anything else apart from installing a power cap that will give me more punch??? i know about batteries and alike, im just wondering about the speedy.
also, the auto start feature on my speedy doesnt seem to work, it says to hold brake for over 5 seconds and then when u go it will launch faster, but i cant tell the difference. i use the auto start feature on my ko mars controller and i can notice a huge difference, but i cant when i use the speedy to do it
please let me know if anyone has information to help me, thanx in advance
robbie lloyd
xray racer is offline
Old 01-15-2004, 12:26 AM
  #129
Tek Nickal's Avatar
I installed a big @$$ capictor in my car, very punchy.
Tek Nickal is offline
Old 01-15-2004, 12:37 AM
  #130
Hey AzNDRAGster, noticed you're from SF. Where do you race? RC Tech?
was ist los? is offline
Old 01-15-2004, 02:47 PM
  #131
Hebiki's Avatar
Trader Rating: 26 (100%+)
trying install TWO and using fukuyama batteries. i have two of the "bazooka" sized ones from Ko Propo on my VFS-2000. asked robert if i can use two.. he laughed.. "ya.. masami uses two" and i said.."hell, if masami doesit, im gonna do it too! "
ill post pictures of it if you guys wanna see.
Hebiki is offline
Old 01-15-2004, 02:51 PM
  #132
rc-zombies's Avatar
or you can use only 1 Novak capacitor
the KO caps are rated 1000uF the Novak is 4700uF... and I have one rated at 10,000uF
Old 01-27-2004, 04:38 AM
  #133
Registered User
Hi Everyone,
I was looking for another capacitor to put into my novak cyclone, and I saw one that say 50V @ 22 MFD!!!! This is from a speaker cross over board. I am not sure if this is correct( number that high!!! or misleading). But I might give it a try.... LOL
Have anyone see this figure before???
Thanks,
TheNoi is offline
Old 01-27-2004, 04:51 AM
  #134
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
as far as i know, esc caps smooth out power spikes and dont improve motor performance.
solder a cap onto the motor and watch what happens, its like a turbo when its on the dyno, but on the track it charges up then discharges into the motor causing acceleration when you dont want it. thats what happened when i tried it.
dontfeelcold is offline
Old 01-27-2004, 05:22 AM
  #135
Moderator
Pro ten Holland's Avatar
Originally posted by TheNoi
Hi Everyone,
Thanks,
It's a reular figure for such a cap. There are even heavier ones available. All will damage your ESC. The cap on the ESC helps the FET's in the ESC switch faster. Using just any capacitor will not help the FET's, they might not even shut at all. This results in an on/off switch feeling of the ESC. The ESC will run hot and might even be damaged. If you want a bigger capacitor, get one from your ESC's manufacturer. The problem is regular capacitor are designed to work at 1000Hz (1KHz) max. Todays ESC's switch at much highre speeds. The maximum usuable frequency is not specified with regular capacitors. I used a reular capacitor, and my car felt faster, but the ESC ran very hot. Don't make my mistake!
Using a larger capacitor isn't nescessary, it will only slightly improve performance.
Pro ten Holland is offline
