Monster Horsepower Stock Tuning
#17
can/endbell
evaa-is it free?
#18
Re: Can / Endbell
Evaa - sorry, I am keeping them as a spare
#19
Originally posted by The Black Kat
Been there, done that...
#21
I usually run the Fantom 315 brushes with hard springs on the tight tracks and medium springs on large tracks.
If I'm not to picky I run 2-3 packs without cutting the com. But I use the com stick and a small fiberglass brush on the brushes. If I'm picky I true the com before every run and use the fiberglass brush on the brushes, then change brushes after 2 packs. This is when I'm racing. When practicing I run 8-10 packs before I do anything...
Sigmund
Sigmund
#23
Re: Monster gearing
Originally posted by wikedgmc
Hey black kat, I run my monster pro at a 7.5 to a 7.9 at Hobbyworld and I have yet to burn up a motor, maybe you got a bad motor.
Kevin: I'm glad I didn't hurt the motor...Thankfully I got my speed control reset (again) before that main
#24
Originally posted by evaa
yep, exactly anyone looking for a monster pro can and endbell?
If its a good price (free) I'll take it
#26
Originally posted by fatdoggy
It all depends on your rollout, I run a 6.5 on a medium sized track. If I went to a large track I'd be running around a 6.0.
Stegger - I'd say start with a 24mm rollout and go from there.
rollout - (tire diameter in mm x 3.14) / Overall gear ratio
(24mm x 3.14) / 7.8 = 9.7
I run in a fairly tight track.
#27
Oppssss. I screw'd up. It's supposed to be "tire width".
Sorry about that.
Sorry about that.
#28
DOMOisCOOL - So your rollout is 20.55 if you run rubber tires. I usually take the gear ratio to the second decimal place becuase when you run foam it you can make finer adjustments on your rollout.
#29
I usually run Red springs, with either Reedy 767's, Trinity 4499, or Putnam greens. I have yet to try hurricane gold though. I heard they were pretty good. I am gearing at about 8.3 Final drive ratio with rubbers on a tight carpet track. It's just a nice balanced setup that I've never had any problems with power.
-Sushi Boy
-Sushi Boy
#30
roll out is not affected too much when rubber tires are used right? basically,the computation is constant (i mean depending on the gearing). am i correct? what roll out would be good for a midsize technical track using an xray FOC, stock motor and 90 spur gear?
tanx guys.
tanx guys.
