arm wire diameter >
arm wire diameter
arm wire diameter
Old 06-08-2004, 11:02 AM
Default arm wire diameter
which is better for stock motors......thicker guage wire or thinner wire..........i have 2 stock motor arms sitting in fornt of me and one has thinner wire and nicly stacked and the other has thicker wire and is not as nicely wound
h22ah is offline
Old 06-08-2004, 11:18 AM
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
5-25: Stock motors will be wound using a "Mabuchi" cross wrap technique, and a process that
locks commutator and the armature stacks, so that the timing cannot be changed without
disassembling the motor. The legal stock wind is a minimum of 64 inches of round 22 AWG
(American Wire Gauge) wire, having a maximum wire diameter (including insulation) of .67mm,
resulting in no less than 27 continuous turns of wire on each pole. A production tolerance of one
turn on one pole is allowed. There is no tolerance on the minimum length of wire or a plus
tolerance on wire diameter.
Tres is offline
Old 06-08-2004, 03:25 PM
sosidge's Avatar
Default Re: arm wire diameter
So one of these motors is not a legal stock...
sosidge is offline
Old 06-09-2004, 10:18 PM
my track isn't really that strict about roar legal or not so it's not that big of a deal
h22ah is offline
Old 06-10-2004, 09:01 AM
rcsabah's Avatar
the thicker one should give more performance if the winding is the same
rcsabah is offline
