Foam Tires - Front or Rear >
Old 08-06-2010, 06:01 AM
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Default Foam Tires - Front or Rear
Is there any difference between a Front or a Rear tire? I see tires advertised as "26mm 40 Shore Front" "30mm 35 Shore Rear", etc....
Are they different compounds or construction? Or is it just a different way to differentiate between 26mm and 30mm?
I need, but I can't find anyone who sells 26mm Rear Tires.
Sith Lord is offline
Old 08-06-2010, 06:08 AM
Conrad's Avatar
The construction of the tire is different front to rear on most brands, although Gecko foams don't differentiate front and rear. Schumacher sell ATS foams that are 26mm wide and Gecko offer this size as well.
Conrad is offline
Old 08-07-2010, 06:18 AM
Sith Lord's Avatar
Thanks Conrad. I'll look into those brands.
For anyone, but someone standing on the podium at the Worlds, will I notice the different conpounds Front to Rear????
Old 08-07-2010, 07:09 AM
FK05 lover's Avatar
Trader Rating: 147 (99%+)
At the 2010 ACT titles in one qualifer Matty Stamboulos's Dad George mistakenly put one front on the rear & visa versa
The car was undrivable, you will notice it
FK05 lover is offline
Old 08-07-2010, 07:48 AM
Bingo! Fronts are designed to last and rears are designed to grip in simple terms. You can run rears on the front for more steering but a 40r on the front will turn about the same as a 37f but with twice the wear. Any front on the rear will just be a joke. For simple use run one shore harder front compound on the front of your car and it won't be hard to get the handling right.
Dragonfire is offline
Old 08-07-2010, 08:56 AM
A Ilievski's Avatar
Trader Rating: 39 (100%+)
At the titles George had mistakenly set the car up like this.
42fl
37fr
37rl
42rr
Any car would be undrivable with that combo!!
A Ilievski is offline
Old 08-07-2010, 09:00 AM
wingracer's Avatar
Trader Rating: 24 (100%+)
Front rubber is different from rear rubber. All you have to do is true them to see the difference. A good truer will slice right through a 40 rear but put a 40 front on it and try to take the same big cut. The thing will bog down and smoke will role.
wingracer is offline
