arm wire diameter
arm wire diameter
which is better for stock motors......thicker guage wire or thinner wire..........i have 2 stock motor arms sitting in fornt of me and one has thinner wire and nicly stacked and the other has thicker wire and is not as nicely wound
Company Representative
5-25: Stock motors will be wound using a "Mabuchi" cross wrap technique, and a process that
locks commutator and the armature stacks, so that the timing cannot be changed without
disassembling the motor. The legal stock wind is a minimum of 64 inches of round 22 AWG
(American Wire Gauge) wire, having a maximum wire diameter (including insulation) of .67mm,
resulting in no less than 27 continuous turns of wire on each pole. A production tolerance of one
turn on one pole is allowed. There is no tolerance on the minimum length of wire or a plus
tolerance on wire diameter.
Re: arm wire diameter
my track isn't really that strict about roar legal or not so it's not that big of a deal
the thicker one should give more performance if the winding is the same
