Novak SS5800 glitches >
Old 06-07-2004, 05:45 PM
StoneMan's Avatar
Default Novak SS5800 glitches
I hope someone can help I'm the only one locally that has this set-up.
For two weekends now I have been experiencing the same problem.
The car turns and goes to full throttle with no warning.
More than once
Car: Tamiya EVO III SE
Gearing 35/96 7.13-1
JR XS-3 radio and JR receiver
I have tried: Novak XXtra receiver
relocated receiver
moved ESC to different spots
Motor temp when glitching starts is between 130-145 deg.
Andy
The power has surprised a lot of racers until it turns left and tries to attack a marshall
StoneMan is offline
Old 06-07-2004, 05:59 PM
burbs's Avatar
contact novak.. they are very good about making sure there products work properly.. they would know the answer
http://www.teamnovak.com/
burbs is offline
Old 06-07-2004, 07:22 PM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
You should also check your crystals to make sure they are in good condition.
Randy Caster is offline
Old 06-07-2004, 07:28 PM
When does your problem occur 1 min, 5 mins at the end of the bat pack capacity.....?
vadn1 is offline
Old 06-07-2004, 07:37 PM
StoneMan's Avatar
The car doesn't have crystals its a synthsised radio
The glitching startd about 1 min. into the main. When I picked the car up both the wheels and motor were jumping back and forth.
Andy
StoneMan is offline
Old 06-07-2004, 07:39 PM
You might want to test the car with another ESC setup before bieng sure it is the SS5800. A non synthesized radio can lose its signal strength with age and will need to be retuned, I'd think a synthesized setup would need this much more often.
Old 06-07-2004, 07:46 PM
StoneMan's Avatar
I pulled out the SS5800 and reinstalled my 19T and GT7 and no problem.
I use the same radio for my R40 & F201 so I'm sure its not the radio.
Also changed receiver to the Novak synthsised.
StoneMan is offline
Old 06-07-2004, 08:11 PM
Joel Lagace's Avatar
maybe the comm needs to be trued?
Joel Lagace is offline
Old 06-07-2004, 08:19 PM
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I have a couple of them and the only time I've ever had a problem was when the input cable was damaged/cut/frayed.
They unplug from the ESC, so they're easy to replace.
It would have to be pretty f'd up to just run away, they kinda "park" themselves if they don't see a valid neutral signal. They won't run away if you turn off the radio first.
Turbo Joe is offline
Old 06-07-2004, 08:30 PM
Never mind this....
aviaar is offline
Old 06-08-2004, 04:30 AM
kufman's Avatar
Check your switch harness too, mine had a similiar problem when my switch was about to fall apart. sounds like a bad electrical connection or a bad unit. If you can, have some one else try your ss5800 in their car with their radio setup. I run the same radio with a 5800 without trouble. How old is the novak motor system? If you can't find the problem give novak a call, they seem to be pretty good about working with people to figure out problems with the brushless stuff.
kufman is offline
Old 06-08-2004, 09:47 AM
StoneMan's Avatar
Thanks to everyone
When I get home tonight I'll check it all out.
I e-mailed novak as well.
Joel you live too close to politicians
Andy
StoneMan is offline
