Lipo dilema
Old 08-03-2010, 06:03 AM
Default Lipo dilema
Hi to all,
i have a question about lipo 7.4v pack configuration.
What is better 2s2p 50c or 2s1p 45c same mah, same brand, for stock racing?
2s2p containing 4 cells are harder to balance and more volatile then 2s1p that's made from 2 cells, right?
What do u think about this?
tomislav is offline
Old 08-03-2010, 06:13 AM
Pablo Diablo's Avatar
I am not 100% on how the different configurations perform against each other, but, no difference when it comes to balancing. Cells wired in parallel must always be at the same voltage, so no difference really.
Pablo Diablo is offline
Old 08-03-2010, 07:00 AM
sosidge's Avatar
Originally Posted by Pablo Diablo View Post
I am not 100% on how the different configurations perform against each other, but, no difference when it comes to balancing. Cells wired in series must always be at the same voltage, so no difference really.
Differences in cell degradation can mean that a 2p pack could have one cell drop without the other being affected. The voltage would read the same but the capacity would be down and the pack would fall out of balance.
For that reason I would always go for a 1p pack if possible because then you can monitor each cell individually.
sosidge is offline
Old 08-03-2010, 07:04 AM
Joel Lagace's Avatar
agreed. Along with the whole balancing issues, there is also the issue of resistance. There are less soldered connections holding together a 1p pack vs a 2p pack.
Joel Lagace is offline
Old 08-03-2010, 07:10 AM
Skiddins's Avatar
Thunder Power seem to be generally regard as the best lipo....and they are 2s2p.
Also, having the 'resistance' of the cells in parallel reduces their total resistance.
Basically, I wouldn't worry about any of it, unless you're buying cheap crap packs.
Skiddins
Skiddins is offline
