Foam Tire On Ep Cars
Anybody knows what is the best Foam tire Brand and shore can be used on EP cars..????
I recommend Jaco 28mm tires, plaid/purple or orange-d.pink/d.pink. If you talking only shore ratings 40/35.
Thq, FatDoggy...
And can u comments about this Speed Mind Foam Tire, is it can be used on EP too..???? and what type of shore u recommend if used this Foam tire...?( compatible with EP )
Yep I've run them on carpet but never on bitumen. I used 40 shore front/ 35 rear. I'm pretty sure they were the 26mm sweeper models. Some people like speedminds and others don't. When I ran them I liked them but they required that I change my setup for them to work. If you want guaranteed traction 'no matter what' then stay with jaco, if you don't mind adjusting setup to get them to work then try speedminds(there cheaper too).
Thks. FatDoggy
I will tried Both Jaco And Speed Mind..
Foam
I prefer elligi foams, so does pretty much everyone else around my area, although I live in Australia and not sure if it is different in different countries. I have seen that we use 42 front 40 back cause you dont have to buy tyres as much.
Difference in car setup from rubber to foam
as above
leekayliang - In general rubber tires like softer setups them foam tires.
Can anyone post the basic setup for using Foam tire on a Aspalth or Tarmac Track..??
