Lipo Storage Voltage >
Old 07-31-2010, 07:52 PM
Clint161's Avatar
Default Lipo Storage Voltage
What is the correct voltage per cell for storing Lipo's?
Thanks for the info!!!
Clint161 is offline
Old 07-31-2010, 08:45 PM
RLMW VQ's Avatar
fyi bantom chargers have a lipo storge setting the charger will do all the work you just push the button.
RLMW VQ is offline
Old 07-31-2010, 10:09 PM
JKL1031's Avatar
and how long a "storage" time is required to do this.
JKL1031 is offline
Old 07-31-2010, 10:33 PM
Clint161's Avatar
I just got a new Hyperion Duo3 and it's storage is at 3.0Volts per cell.
Is that OK? I just thought that sounded low.
I know when my battery hits lipo cut off with my Tekin RS it is at around 3.4V per cell.
Clint161 is offline
Old 08-01-2010, 03:54 AM
The best storage value is around 3,7-3,85V per cell
Nilks is offline
Old 08-01-2010, 04:07 AM
sosidge's Avatar
That sounds very low. Do you have the settings right?
I have the Hyperion 0606i and the "store" mode takes the cells down to around 3.9V.
I would say anything below 3.7V (the nominal voltage of the cell) is too low.
sosidge is offline
Old 08-01-2010, 04:17 PM
I suspect the 3.0V per cell value you are seeing is for the discharge setting.
The storage process is separate, it will go to about 3.85V per cell. (7.7V for a 2S) Charge or discharge as needed. Seems to be in the range of many if not most recommendations.
Dave H is offline
Old 08-01-2010, 04:50 PM
c-lyon's Avatar
Clint, does your Duo3 storage work for 1s packs? Thanks.
c-lyon is offline
Old 08-01-2010, 05:08 PM
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
ask the manufacture,not every one is the same
20 SMOKE is offline
Old 08-02-2010, 03:35 AM
The common wisdom is basically 50-60% charge so simply charge em normally till the hit 8.0v (2s) then stop and pack away. I also use the storage mode on my charger between meets and have had awesome packs for a long time now though I think that is far more to do with the brand than storing them.
Dragonfire is offline
Old 08-02-2010, 03:41 AM
I think allso that brand is critical to lipo life, can PM me what brands u think are best.
tomislav is offline
Old 08-02-2010, 04:44 AM
around 3.7v-3.9v per/cell
teamsanwa is offline
