oneway for rubber on carpet >
Old 06-05-2004, 10:21 PM
rc_square24's Avatar
Default oneway for rubber on carpet
generally, how would a oneway work w/rubber tires on carpet compared to a diff in the front?
FYI- im running a Pro4.
Thanks in advance
rc_square24 is offline
Old 06-05-2004, 11:26 PM
Korey Harbke's Avatar
The car would have more steering and it would roll through the corners to carry alot more corner speed. Just use a no brakes driving style and you'll be set. I shaved .4 sec per lap when I first switched from a diff to a one way.
-Sushi Boy
Korey Harbke is offline
Old 06-06-2004, 12:06 AM
If you normally run little to no toe-in with a diff then toe it in a bit
The Black Kat is offline
Old 06-06-2004, 03:11 AM
Lonestar's Avatar
Trader Rating: 14 (100%+)
Howdy
oneways require a different driving style. You must be smooth, not use the brakes and be extremely consistent and focused, because the car has quite a lot more steering off-power, which makes it easier to hit the inside cones in the turns (and flip over...). Pretty much everybody will turn faster lap-per-lap times with one on carpet with rubbers, BUT not everybody will be faster over 5mns because of a higher mistake occurence...
At a higher competition level, pretty much everybody runs onewys on carpet with rubbers in Europe. My advice: if you can't do a perfect run with 2 diffs, don't try oneways. If you can run 5mns with each lap in the same 3 tenths of a second, then try one.
Recommended setup changes: a little less toe-out up front, and a stiffer suspension (both to tone down turn-in)
Later,
Paul
Lonestar is offline
Old 06-06-2004, 09:30 AM
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Good input
OVA is offline
Old 06-06-2004, 01:52 PM
Lonestar's Avatar
Thanks. It's another hopup that is not recommended unless one is a seasoned racer...
Later,
Paul
Lonestar is offline
Old 06-06-2004, 02:32 PM
Super Steve's Avatar
doesn't more front toe out give you more aggresive turn in?
Super Steve is offline
Old 06-06-2004, 02:35 PM
fatdoggy's Avatar
Yes, lonstar said "run less toe-out"(if you run toe-out) becuase the front-oneway gives alot of steering.
fatdoggy is offline
Old 06-06-2004, 02:43 PM
oops,
my bad,
I thought he suggested to run more
