Old 09-23-2010, 08:28 PM   #121
The MurfDogg's Avatar
kschu - You have PM
Matt "The MurfDogg" Murphy
MurfDogg Racing - www.MurfDogg.com- ROAR National Champions!
Brushless Racing Motors - Li-Po Racing Batteries - Aftermarket Accessories
Luxury Dirt Oval Racing Chassis and Performance Accessories
The MurfDogg is offline   Reply With Quote
Old 09-23-2010, 08:36 PM   #122
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
where's the onroad team drivers on the web site
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-23-2010, 08:53 PM   #123
superspeed's Avatar
Why would anyone run negative timing unless you're using reverse rotation on purpose.
When timing was introduced on brushless motors, I instantly thought about the good old days tweaking brushed motors.
Can you provide some dyno readout for the 13.5, 17.5?
superspeed is offline   Reply With Quote
Old 09-23-2010, 09:38 PM   #124
wingracer's Avatar
Trader Rating: 24 (100%+)
I don't know about Murfdogg motors but on most brushless motors, 0 isn't 0. So setting the endbell at minus 5 could still be +5.
With boosted esc's, you usually want little or no motor timing and use the esc's boost and/or turbo functions to get the timing you want.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-23-2010, 10:22 PM   #125
Smoke20 - They will be updated shortly... Im just glad to have the site back up!
Old 09-23-2010, 10:34 PM   #126
Brushless motors have timing built into the sensor boards. The timing marks on the can are reference points, not actual static motor timing.
I can provide Dyno numbers. However, unless you use the CE Turbo Dyno like I do, and run it at the same settings I use in a controlled environment, the Dyno Sheet will not tell you much. It will look like a piece of paper with numbers that you have no reference to. I do not use the Fantom Dyno which bases its numbers off RPM and Amp draw. My dyno gives the motor a true load, which is the only way to actually Dyno a motor with usable results.
What kind of useful info are you looking for? I would be more than happy to do what I can to help you with whatever you are trying find out about these motors.
Matt
Old 09-26-2010, 06:17 PM   #127
TVMRocket69's Avatar
Send a message via AIM to TVMRocket69 Send a message via Yahoo to TVMRocket69
Got to run my 13.5 today. Motor has awsome bottom end. I was able to put a bigger pinion on and still had punch to spare. After 8 had minutes motor was only 136 degrees. Great motor. Murf I will be ordering some more motors very soon. Thanks for a great BL motor.
Bob Walker Jr.-Sponsor's-
AnswerUSA-RC Team Driver, G's R/C Raceway Team Driver, RBMods Team Driver, Kosmic R/C Fuel Team Driver, MurfDogg Motorworks Team Driver, Serpent S811B, Serpent S811t, MurfDogg Powered V-Desizn Carpet Ripper 5
TVMRocket69 is offline   Reply With Quote
Old 09-26-2010, 07:27 PM   #128
Rocket - Glad to hear you like it! PM me with your setup so I can see where you are at.
Matt
Old 09-26-2010, 08:31 PM   #129
Murf you have PM.
Old 09-26-2010, 09:16 PM   #130
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Im Sure you will have more orders for some motors from louisiana after the guys saw my 17.5 run in 12th this past friday.
micrors4guy is offline   Reply With Quote
Old 09-28-2010, 11:50 AM   #131
Default Stock Update
17.5 and 13.5 motors are out of stock. I have another batch on the way, and am hoping they are here end of the week... fingers are crossed. 10.5, I only have 1 or 2 left right now. 4.0, 4.5, 5.5, 6.5 turn Mods are in stock and ready to ship.
Thanks for all of the Support guys!
Matt
Old 09-28-2010, 12:35 PM   #132
johnny boy's Avatar
Trader Rating: 267 (100%+)
motors in stock at High velocity racing
www.highvelocityracing.com
JOHNNY CHASE
Team associated, Reedy, schelle racing, Lunsford, Lead finger racing
johnny boy is offline   Reply With Quote
Old 09-28-2010, 01:58 PM   #133
We have limited quantities of Black Synergy Stealth 4.0 and 4.5 turn mods left.
Old 09-28-2010, 02:11 PM   #134
crawlinallday's Avatar
Need some help with my Murfdogg 10.5
Sent you a pm.
Thank
Wade
RC a SICKNESS
crawlinallday is offline   Reply With Quote
Old 09-28-2010, 02:13 PM   #135
JayBee's Avatar
Trader Rating: 31 (100%+)
So Matt....there's no more BLACK 13.5's left?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
