Old 06-12-2005, 03:39 AM   #196
Registered User
Hi-LowBrow's Avatar
Send a message via Yahoo to Hi-LowBrow
Originally Posted by FUK_WRX
Hi-LowBrow: You got any good set-ups for semi-technical, high grip track? Any hop-ups you recommend? Need to set up the car using Sorex 36R w/C medium inserts. Thanks
Yes FUK_WRX,
I've been racing at technical high grip track and got good set-up for the Monster.
<shock position> Front No4 position (No1 is the inside)
Rear No4 position
<droop> Front 10.2mm (from Ground to center of hinge pin)
Rear 8.2mm
<Ride hight> Front 4.5mm Rear 5.0mm
<Upper arm> position Front=king pin (out side), Lowest (inside)
Rear=upper hole(out side), middle hole(inside)
<shock oil> 40w all the way around
<piston> stock piston with 1.18mm 2 holes (use the pin
<shock springs> Tech Blue (Long) all way around
<sway bar> Front =none Rear=1.2mm
<pivot block hight> F-f 1.0mm(shim) F-r 1.0mm
R-f 1.0mm R-r 1.5mm (anti squad)
<center pulley> direct drive (spool)
I highly recommend you to use the Rear sway Bar and the center strat plate(which you already got on the car)for HIGH GRIP TRACK, since the Car has too much roll on the rear. as well as the rear droop is very important for this car, don't give it too much droop !!
to me with this set up, it is dialed on
hope this helps......
Hi-LowBrow is offline   Reply With Quote
Old 06-12-2005, 04:13 AM   #197
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
Originally Posted by Hi-LowBrow
Yes FUK_WRX,
Rear No4 position
Rear 8.2mm
Thanks for the input, i dont have much set-ups for the Monster on rubbers so this set-up will really help me out. Sux when all people in OZ use foam had to widen my track up front a little to make them work. thanks again..
FUK_WRX is offline   Reply With Quote
Old 07-04-2005, 03:54 AM   #198
ernestf's Avatar
Send a message via ICQ to ernestf
Default Tech MY05
New MY05 is on the way
http://diary5.cgiboy.com/3/techracin...i?y=2005&m=7#4
ernestf is offline   Reply With Quote
Tech Racing MY02, Tamiya Evo IV, TA05 Afro Puff R/C Items: For Sale/Trade 16 01-05-2008 02:05 PM
tech racing my02 much more todb R/C Items: Wanted to Buy 2 04-29-2005 12:35 PM
Tech-Racing MY02/M RandyB Electric On-Road 2 04-14-2004 02:52 PM
Tech Racing My02 TheBarber R/C Items: For Sale/Trade 6 06-04-2003 04:33 PM
Tech Racing MY02 Macky R/C Items: For Sale/Trade 49 02-11-2003 04:47 PM
