tech-racing MY02 >
tech-racing MY02
tech-racing MY02
Old 01-28-2005, 04:59 AM
  #136
Originally posted by B&O
Ryan,
In your dream that you can test my 415MS.....I want to switch to straight carbon of 415 (from Tech Racing)..........................
Eric,
Not Si II or New X-ray?
Ryan_Lam is offline
Old 02-07-2005, 02:34 PM
  #137
TFR
TFR's Avatar
Anybody have a picture of Much More version of MY02M? Does the MY02M come with all graphite conponents? Or is that option?
TFR is offline
Old 02-07-2005, 03:02 PM
  #138
B&O
B&O's Avatar
Ryan,
Too Bad that you can't play on Friday!!!!!! I will test my 415MS for the first time....................
B&O is offline
Old 02-07-2005, 03:56 PM
  #139
sosidge's Avatar
http://www.much-more.co.kr/bbs/zboard.php?id=car&no=12
This is the Much-More version, with a few accessories - no foam bumper in the kit, no screw washers, no alloy spur gear holder.
I have built one, and although I'm not sure if they are graphite arms (probably not), they are very stiff, as are all the plastic components.
It is a "straight" carbon chassis, mainly longitundinal fibres, this makes it strong lengthways, but quite flexible when twisted. So you can tune the flex with the carbon outriggers.
sosidge is offline
Old 02-07-2005, 04:39 PM
  #140
TFR
TFR's Avatar
sosidge,
Where did you get your kit?
TFR is offline
Old 02-08-2005, 04:51 AM
  #141
sosidge's Avatar
The one I built was from Much-More UK - we're one of their dealers, and I built one up for them as a demo car. I don't actually have the built one any more.
sosidge is offline
Old 02-11-2005, 04:08 AM
  #142
sosidge,
Can u upload some pic for us?
Ryan_Lam is offline
Old 02-11-2005, 04:20 AM
  #143
sosidge's Avatar
I don't have any pics unfortunately - it looks just the same as the car on www.much-more.co.kr but without the bumper and a few of the smaller blue alloy bits, e.g. screw washers, spur adaptor.
sosidge is offline
Old 02-11-2005, 05:01 AM
  #144
kentech's Avatar
Default Tech Racing Shocks
Can any of you who have built the Tech Racing shocks tell me a bit more about them? They look very similar to Tamiya shocks...?
kentech is offline
Old 02-11-2005, 06:09 AM
  #145
ernestf's Avatar
Ryan, no luck to source any MY02M parts in HK ... no one carry them ...
ernestf is offline
Old 02-11-2005, 10:15 AM
  #146
FUK_WRX's Avatar
Default Re: Tech Racing Shocks
feels the same looks the same but the material is a little lowere dan the TRF units, althouh they jsut brought out a new damper unit also similar to the TRF units but they are all anodized and teflon coated i heard. Although they are dead smooth just like the TRF ones.
FUK_WRX is offline
Old 02-11-2005, 10:38 AM
  #147
kentech's Avatar
Default Re: Re: Tech Racing Shocks
Thanks for the answer! Have a few more questions regarding the shocks.
Are the Tech Racing shocks also a 1 o-ring design? Are the plastic parts at the bottom of the shocks similar to the TRF shocks? And finally are the bottom shock end and also the upper end the same size as the TRF shock (i.e. will they fit Tamiya 5mm shock mout balls)?
kentech is offline
Old 02-11-2005, 11:47 AM
  #148
FUK_WRX's Avatar
Default Re: Re: Re: Tech Racing Shocks
the buttom and top end (where ball end fit) is not the same, the plastic parts im not sure off and the o-ring design ill look in my manual little later and ill PM u.
FUK_WRX is offline
  #149
Hi-LowBrow's Avatar
actually Tech Racing makes the TRF shocks as OEM stuff.
Tamiya's oneway bearing is made by Tech racing too.
the Tech Racing shocks which come with the kit are almost same as the TRF shocks, but the Teflon coated shocks(which is called Fusso Baking Powder Shocks) are lot better than the TRF stuff.
the coating is 3rd times more thicker.
Hi-LowBrow is offline
Old 02-12-2005, 12:52 PM
  #150
kentech's Avatar
Thanks again for the info. One more question; would it be possible to use the top ends (plastic) from the TRF shocks on the Tech Racing shocks?
kentech is offline
