LRP SPHERE NEED HELP >
Old 07-27-2010, 01:13 PM
speedlane's Avatar
Default LRP SPHERE NEED HELP
HI
-THERE IS A LRP SPHERE COMPETITION TC SPEC THAT IS STILL FUNCTIONING.
-MOTOR SOMETIMES ROTATE SOMETIMES NOT,NEED A LITTLE PUSH THEN IT ROLL AGAIN,sometimes it just started to roll as normal..
-When motor doesnt rotate,in full throttle the LED appears solid blue & yellow red flashes?...
-I'LL HAVE BEEN CHECKING IT FEW TIMES FROM THE MANUAL GIVEN,BUT NOTHING SEEMS MAKING IT GOING WRONG.HMMM...some say is the esc,some say is the motor,some say is the wiring,some say is the receiver...my brain seems is in the spinning mode...
-Using the EX Novak 8.5t motor with this lrp sphere...recently the xbr sport esc have gone burnt into smoke using this motor cause no proper setting on esc...
-What damage could it be to this motor? still usable?
speedlane is offline
Old 07-27-2010, 04:25 PM
Joven M's Avatar
Had a similar problem. Sounds like a bad sensor wire. Good luck
Joven M is offline
Old 07-27-2010, 07:15 PM
speedlane's Avatar
tanx joven,i'll try it out
