Touring Car Springs: >
Old 07-26-2010, 02:12 AM
Default Touring Car Springs:
Hi, I wanted to start this thread as I would like to get more information on what all the different manufactures springs are like.
So far I've picked up that Tamiya springs are the most progressive and work well on carpet, and HPI are the opposite, linear and best suited to tarmac.( Rhinhard used them at worlds??? HPI silver all round?)
But what about the rest, has any one tested them? AE drivers seem to stick to AE springs no matter what the surface, are they linear or progressive?
Xray drivers some times use HPI springs, even on carpet???
Hope this generates some discussion and gives some tuning options,
cheers
michael.branth is offline
Old 07-26-2010, 02:21 AM
sosidge's Avatar
All the current springs are wound linear.
People choose the HPI springs over the Tamiya springs because of the "feel" on the track, it's a misconception to say they are progressive. The HPI range has much finer steps between rates than the Tamiya range and also run a bit stiffer.
Petit RC have a fairly exhaustive spring chart for reference.
You can be fast on any spring (assuming they are a good basic quality), just select the right rates and dimensions to give the handling balance you want and to fit the shocks.
sosidge is offline
Old 06-14-2011, 05:13 PM
alcyon's Avatar
how about lengths of the different brands of springs?
The old yokomos were 22mm long. The newer ones are 24.5mm i think.
I would be interested to find 20mm and below length springs.
alcyon is offline
Old 06-14-2011, 06:52 PM
sosidge, Do you have a link to said chart?
KBorg is offline
Old 06-14-2011, 07:59 PM
Tron's Avatar
Trader Rating: 17 (100%+)
The charts are here, touring car is specifically the 3rd bullet down:
http://www.petitrc.com/reglages/Univ...pringChart.htm
Personally I feel the HPI and Hara springs feel the same on the track, from linger:
Originally Posted by linger View Post
After sitting on my desk for a year - I finally got around to measuring the Hara Springs. I measured two springs and took an average.
I'm impressed - these spring actually measure very close to the rating on the package - that's rare in the RC world.
The graphs show that the springs are completely linear (with best fit R squared value between 0.9988 and 1.0000 for you technical types).
The measurement was done with a Chatillon 10 lb load cell and a test stand with accuracy within .001".
Hara Springs
66961 Yellow
published = 12.88, measured = 12.97
66962 Silver
published = 14.00, measured = 14.37
66963 Black
published = 15.12, measured = 15.44
66964 Purple
published = 16.24, measured = 16.41
66965 Pink
published = 17.36, measured = 17.57
Tron is offline
Old 06-14-2011, 08:19 PM
BigDogRacing's Avatar
Ummm, how would you know if they're linear progression by only measuring rate at one compression depth?
Answer: You don't know
There's a lot more to spring progression than simply saying "all springs are wound linear". What you mean to say is the latest springs have linear coil spacing. Saying they're all wound linear is false. ALL springs are progressive. But some have a load curve and some load on a more linear progression.
BigDogRacing is offline
Old 06-15-2011, 12:46 AM
To further add to that... The number of coils basically dictates how "progressive" the spring is. When comparing springs of the same (or similar rate) the spring with less coils will be more progressive.
Dragonfire is offline
Old 06-15-2011, 02:56 AM
I don't want to be acting like I know a lot about springs (because I don't), but I can tell you this: My 417 transformed when changing from Tamiya springs to HPI springs (on asphalt). The car was so much better to drive!
I would still choose Tamiya springs on carpet, but for asphalt go for HPI Silvers all around.
Nilks is offline
Old 06-15-2011, 05:42 AM
Viper2011's Avatar
really Ash-pelt and carpet,Regardless..It should not matter,The spring might work a little bouncer on Ash-Pelt but really not much difference between the two.
Viper2011 is offline
Old 06-15-2011, 06:13 AM
I have heard that same thing from so many drivers that I would accept it as fact.
Old 06-15-2011, 08:32 AM
What about the Xray springs compared to the HPI-springs? How do they behave compared to each other?
Skynet is offline
Old 06-15-2011, 05:19 PM
Suspended
Trader Rating: 86 (100%+)
i drive tcx but i use xray springs,
hot bodies pink springs are out of stock anywhere
littlealex is offline
Old 09-07-2014, 07:02 AM
Mitamiya's Avatar
Trader Rating: 15 (100%+)
I need opinions on touring car springs for med grip carpet racing for VTA. Will be using a Tamiya 418. Thanks.
Mitamiya is offline
Old 09-07-2014, 10:19 AM
this might help. for vta run in the 15-16 lb range in front and 13-14 range in the rear. hope this helps.
i run vta only.
for med grip i would suggest 15 ish front and 13 ish in back. i have the rsd carpet spring kit and they are good springs. i run the orange one in front and the blue in the back. car is pretty hooked up tc 6.1 but that car my never hit carpet by me again as now i run a arc r10 2015. have not been on carpet yet with it.
Attached Thumbnails Touring Car Springs:-rsd_universal_spring_chart.jpg
dragonracing is offline
Old 09-07-2014, 02:59 PM
Mitamiya's Avatar
Thank you
Mitamiya is offline
