Suspension Depression Syndrome >
Old 06-03-2004, 02:42 PM
EDWARD2003's Avatar
Default Suspension Depression Syndrome
Hey guess i am soo frustrated with my TC3 suspension. I ve spent a good 2 hours trying to balance the wieght on each corner.
But right now i am stuck. i manage to get weight of.
() 8.5 RR------------- 8.5 RL ()
() 7.0 FR------------- 8.5 FL ()
please help cure my suspension depression!!!!
Thanks!!
Edward
EDWARD2003 is offline
Old 06-03-2004, 02:52 PM
Brian McGreevy's Avatar
Did you try different sets of springs? Do you have any chassis weights on it, and if so, where are they?
Brian McGreevy is offline
Old 06-03-2004, 02:54 PM
EDWARD2003's Avatar
There are no chassis wieghts on the car.. Also i forgot to say that i am ajusting the prelod on the car. And i dont want to change the springs.
Old 06-03-2004, 03:03 PM
I meant do you have any extras of the same rate of springs that you could try?
Old 06-03-2004, 04:28 PM
If your scales are accurate, the simpler way is to put weight nearer the FR, on top of servo.
Remember - don't have the springs compressed when the wheels are of the ground.
Your car, without weight will have always 17 on the left side and minus 1.5 on the right side.
Put all springs equal with, say 1/16 free play and see. I'm assuming that shocks, towers, are equal side to side.
gearless is offline
Old 06-04-2004, 05:48 AM
Essnowyt's Avatar
ED - You have probubly done this, but go back and look at the length of your shock shafts. You want them all the same lenght. Im just trying to work at the basics. Are using threaded shock bodies or the preload clips?
Essnowyt is offline
