RC and Laptops
Old 07-23-2010, 02:48 PM
Jamesalex's Avatar
Default RC and Laptops
Hi, this may sound a stupid question and 'run the laptop from the battery' is the simple answer, but how do you guys run laptops at events if there is no power?
If you battery is getting low is there a way to or some how link your laptop upto your 12v power supply?
Cheers in advance
James
Jamesalex is offline
Old 07-23-2010, 03:02 PM
heretic's Avatar
Cheers in advance
James
If there is no juice, how do you power your power supply ?
heretic is offline
locked's Avatar
If there is no power, then what is your 12v power supply plugged into?
locked is offline
Old 07-23-2010, 03:12 PM
syndr0me's Avatar
Trader Rating: 32 (100%+)
You want a power inverter. Run it off your (big) car battery. They're available in all shapes and sizes.
http://www.dcacpowerinverters.com/
syndr0me is offline
Old 07-23-2010, 03:23 PM
Jamesalex's Avatar
Sorry I worded it a bit wrong.
When there is no access to mains power to plug laptop into and the battery is getting a bit lol, is there a way to charge of the 12v supply or is it just a case of getting an inverter
Old 07-23-2010, 04:52 PM
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
We have no power at our parking lot where we race so a generator is standard equipment. Several racers can use one to share fuel cost and keep noise down.
BCbud is offline
Old 07-24-2010, 11:16 AM
Jamesalex's Avatar
Many Thanks for the replies
Old 07-24-2010, 11:35 AM
MikeXray's Avatar
Trader Rating: 73 (100%+)
See if your laptop maker has a 12v power adapter, I know dell has for most of their systems. You could swap the cigarette lighter to bananna plugs and use your power supply.
MikeXray is offline
Old 07-24-2010, 09:48 PM
Assuming you are using your laptop to program your ESC, just switch it to standby when you are not using it.
Dragonfire is offline
Old 07-25-2010, 07:51 AM
I prefer the inverter option. It lets me run soldering irons and smallish power tools off my car battery as well as my laptop. I have a 750w one but I've seen up to 1500w. I've also got travel adapters for my Dell and Lenovo corporate laptops that come with 12v cigarette lighter adapters. Not sure if Dell has these for their retail laptops or netbooks.
Another option if you're not near your car is to mount a small battery in your tool box. A sealed NS40 or NS60 sized battery should fit in most medium to large tool boxes. My toolbox (http://www.amazon.com/Plano-Molding-.../dp/B000CRBHYE) is on wheels so weight is not too much of a problem and I've been considering mounting an NS40 size in there for use at the track. Would just need to be recharged manually when I get back from the track.
spongerX is offline
