Like Tree13Likes
Old 11-05-2013, 11:48 AM   #616
Originally Posted by terry.sc View Post
Here is the Colt Porsche 956
madgreek is offline   Reply With Quote
Old 11-05-2013, 10:31 PM   #617
HeliYogi's Avatar
Trader Rating: 17 (100%+)
Default Same but electric
I got this one as a gift from Charles L. some unknown Japanese brand. 190mm what's yours?
Glad to see this thread moving on!
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 12-09-2013, 02:54 PM   #618
Trader Rating: 30 (97%+)
its probably discussed in this thread, but what would be needed to fit a tamiya nissan r91cp body to a f201 chassis, the wheel base is 280mm fo both, so what modifications are needed thanks
zaraz is offline   Reply With Quote
Old 12-18-2013, 10:33 PM   #619
HeliYogi's Avatar
Default TCS F1 and more
I don't know the with of the 201, the R91 is at least 200mm so the challenge will be in finding the right offset wheels for it. Also the foams on the R91 are quite taller than the rubbers on the 201 so it may look a little funky with small tires/wheels
Some images I've been taking the past two years as homage to on road / F-1 and TCS - enjoy!
Slide show:
http://s721.photobucket.com/user/Hel...rcos%20Wanless
PS Are you in the photo?
Old 01-11-2014, 01:45 PM   #620
stulee666's Avatar
wheels need to be 9-10mm offset you need to make body mounts and rear wing mounts all of which are easy,mine is on this thread.
stulee666 is offline   Reply With Quote
Old 02-17-2014, 05:52 PM   #621
Ed Delgado's Avatar
Default Porsche 962
It's not a 1/10, but a pic from a few years back of 1/8 Porsche 962 body on a Mugen MRX4. I though you guys might enjoy it anyway.
Am I the only one that likes Group C cars?-962-nnm.jpg   Am I the only one that likes Group C cars?-962_2.jpg
Ed Delgado is offline   Reply With Quote
Old 04-29-2014, 09:38 AM   #622
RnMcustoms's Avatar
i have an custom Carbon Fibre chassis with nissan body on top. The car has all the alu options that ever came out for the car. the pics can be found on my blog. rnmcustoms blogspot com
http://rnmcustoms.blogspot.com
Racing N Modified custom carbon parts -- Still Racing For Fun
Carlist: F102 F103 F104 Corally NGX F1 Spada 09 inferno GT TL01 offroad
RnMcustoms is offline   Reply With Quote
Old 05-01-2014, 09:13 PM   #623
kmas's Avatar
Trader Rating: 59 (100%+)
hey guys, I just picked up a c11 mercedes body set, I have a f103gt lola, what wheels/tires do I need to convert, also where do you guys buy these? thx
kmas is offline   Reply With Quote
Old 05-01-2014, 10:27 PM   #624
The Lola Indy Car?
The Lola Indy Car was the F103L not the GT. To run the C11 you would need to change the upper and lower chassis plates, the front bumper, and body posts. The old C11 was based on a tub chassis F101/102 front suspension. Not sure if the re-release was on the 103 or not.
If you actually do have a F103GT then you would need to change out the rear axle assembly, front steering knuckles and axles, and maybe the front bumper. The F103GT ran touring car wheels with hex adapters...the C11 runs the foam tire rims.
Old 05-01-2014, 10:33 PM   #625
Pro10noob's Avatar
For rims yes.
For tires, take pro10 donuts as you have more shores.
Regards Roy
Originally Posted by InspGadgt View Post
The Lola Indy Car?
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 05-05-2014, 06:57 PM   #626
kmas's Avatar
The Lola Indy Car?
the more I think about it the more I just want to get another chassis, are these hard to come by? what and where do I look, is there a f1 that could be converted easily? thx guys
Old 05-05-2014, 08:40 PM   #627
HeliYogi's Avatar
Default Different beasts...
The Inspector is right on, between a C group chassis (C-11, Mazda 787B, Nissan R-91, Ferrari GTO, Nissan 240? and the Devil (something) and the F103 GT or the F101/102/F103 (L RM RS an LM) chassis there is very little in common.
I love the group C cars, you can run them on the original foams tires or fit F104 size rubber tires on the original rims and they are good to go! check out the photos I have on older post here. These cars are so easy to dial and fast that we used to beat the F103LM (all powered by silver cans) in our club races at Camarillo, CA
The F103 GT Le Mans (with sedan wheels & tires) is easier to convert to a F101-103 (F-1 or LM) type car. There you cold do some adjustments, adaptations and transplants
My .02 is enjoy the C class!
Old 05-06-2014, 01:29 AM   #628
Peter $'s Avatar
I bought a C11 body, which I planned to put on my old F101 - just for fun.
But the F101 wheelbase is much smaller than is needed for the C11. So you really need the original tub-chassis to make it work.
My car:
Peter $ is offline   Reply With Quote
Old 05-09-2014, 09:13 PM   #629
kmas's Avatar
thx for info guys, if you know of anyone with a c11 chassis to sell lmk...
Old 05-09-2014, 10:26 PM   #630
Well according to a site I found on-line the wheelbase of the C11 is 28cm. The Lola Indy Car which is built on the F103L chassis (L for long) is just a couple mm longer than 28cm. So if you have the F103L chassis and not the F103GT chassis then you could probably make it work. You would need the front bumper from the F103LM since it has body post positions on the bumper. Then you would need body posts of the appropriate height to mount the body. However it is likely the body mount positions will not be the same so you will have extra body holes in the body since they usually come pre-cut on the C11. I believe the Indy car rims are very close in size to the C11 but you might need to true the tires down some.
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
FSEARA 2009 turbodog Florida Racing 493 09-16-2008 02:45 PM
