Like Tree13Likes
Old 06-14-2012, 03:49 AM   #316
Hi all,
I really like the group C cars, and it is a shame we have no interest where I stay, in fact getting people out to Race anything here is difficult.
I have the Advan Courage kit but I will likely never run the body because it is unlikely to be released again and I love it's shape.
I am therefore looking for a suitable body to use so I can make vroom sounds while I haul it around the track on its own! Lol.
The courage kit uses the 12mm hex and even with the widest tires I have, the wheel base is around 180mm. I would like to put TC bodies or group c, but I need to get the track wider. I saw 3Racing did a 4mm widening kit for it, but they are nowhere to be found.
Will I have to convert it to run F103 sized tires/wheels?
sirandy is offline   Reply With Quote
Old 06-14-2012, 06:15 AM   #317
If you want to run it just stick a 190mm body on it and run it.
The F103GT is about the same width as most touring cars as it is, maybe a millimetre or two narrower. 190mm touring cars aren't exactly 190mm wide.
If you do want to widen the car then get some wider offset wheels, HPI sell a wide range of 6mm offset wheels which will add 12mm to the chassis width, if you want to go really mad Speedmind sell wheels with up to 10mm offset which will add 20mm to the width.
terry.sc is offline   Reply With Quote
Old 06-14-2012, 09:55 AM   #318
macavant's Avatar
Trader Rating: 64 (100%+)
I just ordered a GT body from ABCHobby along with a diffuser, and bumper for my F103GT. I'm with you on the Courage body - it is a great detailed body and would be a shame to destroy on the track. The GT or Response body costs considerably less than the Tamiya Courage body. I say run the GT or Response and save the Courage for shelf duty.
check here : http://www.abchobbyusa.com/partsfortamiyaf-103.aspx
likes the oldskool RC action...
F201☆F104WGP☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01.G6-01.SandScorcher☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 06-14-2012, 03:48 PM   #319
Bishy's Avatar
Originally Posted by RoyU View Post
Thanks. Would you know his emai?
You have a PM
"I'd rather a bottle in front of me than a Frontal Lobotomy"
TeamC TM2V2, TM4, T8EV3, T8V3, TC10, AE B44.1, B4.1WC
www.teamcracing.net
Bishy is offline   Reply With Quote
Old 06-15-2012, 01:18 AM   #320
Pro10noob's Avatar
@Bishy...Could i have it also?
Thinking of widening my 10R5 also.
regards Roy
Originally Posted by Bishy View Post
You have a PM
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 06-15-2012, 03:03 AM   #321
2wdrive's Avatar
A new/old shell for my 235mm RC10R5... Solid 80's paintscheme and timeless 962 ruggedness!
What brand body is that Porsche 962?
www.rc-lemans.de
2wdrive is offline   Reply With Quote
Old 06-15-2012, 03:21 PM   #322
???E-Racer's Avatar
Im surprized we are struggling just to keep touring cars here in the winter.
Are these like a pan car chassis? They sit lower to the ground than a touring car would.
Novak, Viper, LRP
4wd Slash Platinum,4WD SC10,Stock Slash Latemodel Oval,Losi Slider,E-firestorm Bomber, Team Terribles,www.rkhobbies.com,GOLFLAND USA
???E-Racer is offline   Reply With Quote
Old 06-15-2012, 03:22 PM   #323
RonF's Avatar
I have an old parma decal set for the Silk Cut Jaguar. Ive always wanted to do a body for it since i cant sell the decals. I noticed a XJR14 on Rcmart for F103. I have a f104pro and dont mind converting. any ideas if that body would work? I believe my decals are more for the XJR12, so i would keep the rear wheels covered.
VBR,
Ron
F104pro, Turnigy Turbo 80amp, 21.5 trackstar, LRP esc and Rs 540
RC10 original, RC10 graphite, RC10 4wd MIP SP1 version, RC10T
Associated TC4
RonF is offline   Reply With Quote
Old 06-16-2012, 03:43 AM   #324
sir miles's Avatar
Trader Rating: 23 (100%+)
Hello! Its nice to have this Thread! I recently bought a F104W GP and raced it the first time. I loved it instantly! I ws a die hard 4wd Off Roader, Its rainy season here in Manila Philippines right now and I have to scratch my RC itch. We have an indoor racetrack nearby and its perfect for racing this time of the year. i love my F1 right after my first race and now im eying this.
should be fun too.
gaining momentum!
sir miles is offline   Reply With Quote
Old 06-16-2012, 06:53 AM   #325
Yes they are pan car chassis.
When Tamiya created the Group C kits to fit the different bodies they needed to be able to vary the wheelbase, so they replaced the chassis on their F1 cars with a moulded tub and a separate front section so it could be built in three wheelbases, with a couple of coloured plastic upper braces to stiffen up the chassis. The front and rear ends of the Tamiya Group C cars are identical to their F102 F1 chassis.
Although these days the bodies are quite often mounted on converted f1 chassis instead.
Old 06-17-2012, 03:59 PM   #326
Bishy's Avatar
regards Roy
Done.
www.teamcracing.net
Old 06-17-2012, 04:01 PM   #327
Bishy's Avatar
Hi 2WD, it's a bit of a vintage - PTI, from the old HPI Super Nitro I believe.
Cheers
www.teamcracing.net
Old 06-17-2012, 04:26 PM   #328
Pro10noob's Avatar
@Bishy.....Thanks and you have a reply.
regards Roy
l===/o\===l
Old 06-17-2012, 05:34 PM   #329
The 962 from earlier post is 200 mm.
We're planning 3 decal sets, the Rothmans, Goodrich and FromA
ptiracing is offline   Reply With Quote
Old 06-18-2012, 10:00 AM   #330
Was it made for WGT and/or Tamiya F1 cars?
RoyU is offline   Reply With Quote
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
FSEARA 2009 turbodog Florida Racing 493 09-16-2008 02:45 PM
