Which Lathe?
#16
Oscar Jansen recomends that you start with Carbite and then replace it with Diamond when you've learnt the basics.
#18
Thanks guys for the input. I have never used a lathe so i will take your points on board....
#19
I haven't heard anyone mention the orion lathe. I haven't used one yet but I've heard from those who have that it is very nice and nicely priced.
#20
I have the Hudy Tech Lathe with bearings and the adjustable slides. The adjustable slides are awesome as they allow you to tighten the blocks up against the armature along the direction of the shaft (i.e. you do not have to shim).
This is easily the best lathe that I have ever used. One more thing, if you do get the adjustable slides, make sure to use shims in between the armature and the slides. The spinning armature WILL WEAR a giant hole through the blocks, if you do not use a teflon shim.
#21
Shimming... I just stick a pinion on the arm once it's on the lathe with a teflon shim on each side of the block so nothing is damaged. Keeps it very secure.(eagle lathe)
#23
On my eagle lathe the depth adjustment isn't as fine as I'd like, but as long as you take your time you can get around it easily enough. Other then that I'm very happy with mine, gives awsome cuts and was much cheaper then anything else out there.
#26
Originally posted by evaa
i noticed that no one mentioned the eagle lathe, any inputs?
on the subject of shimming the lathe ...
i put a pinion gear on the armature and a couple of washers to sandwich one v-guide - this way, i dont have to shim both sides of the armature. when looking at the armature from the side, it goes like this ...
pinion + washer + v-guide + washer + armature + v-guide
not very clear but i hope you get the picture
#27
I have the Orion lathe, it is great. It is very easy to setup, you do not need to put a pinion on the shaft, it has set screws on either end to hold the shaft in place. That makes it very easy to change the setup between different arms. It also comes with a slave motor, switch, wires, and of course a bit. All you need is a power source. Good price too, I got mine from my LHS for $130.
#28
