Old 12-20-2001, 07:31 PM   #151
ernestf's Avatar
Send a message via ICQ to ernestf
kitracer, i run kx1 as well. what do u mean by cut the rear arm-mount to get more toe-in ? can u explain more ?
ernestf is offline   Reply With Quote
Old 12-20-2001, 09:26 PM   #152
kitracer's Avatar
Cut the plastic part where the lower arm pin goes through.
Becareful, cut small amount on each side equally or else you will end up with different toe-in.
Actually, depends where you race your car. If you race on slippery surface, I will go up to max 3 degree toe-in, If you race at permanent track that have good grip, the standard 2 toe -in is fine.
kitracer is offline   Reply With Quote
Old 12-21-2001, 11:39 AM   #153
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
kit,
that's nice. did you make that chassis plate? nice work. later.
seaball is offline   Reply With Quote
Old 12-21-2001, 07:06 PM   #154
kitracer's Avatar
Car "was" belong to the Kyosho Team driver from Japan (Itoh) , now belong to friend of mine in HK also a Kyosho driver.
The centre of gravity is now very low. the main drive shaft and pulley have been lowered by 3mm. the batteries sit on the middle but lowered. you can adjust the batteries to move further up
front for more steering.
Old 12-26-2001, 03:54 PM   #155
Hey Kit will those parts become available for sale?
slamminsam is offline   Reply With Quote
Old 12-27-2001, 04:07 PM   #156
Send a message via ICQ to Colossus
big bummer for me.
I'm going to be waiting until february until I get the ball diff thrust spring. until then i'm out of commision.
unless anyone has any ideas. i'm think about ordering one for an ultima rb and use that one. will that work?
Colossus is offline   Reply With Quote
Old 12-27-2001, 04:47 PM   #157
seaball's Avatar
dunno, but february is a long time away. hehe. i'd give it a shot. got my diff for the front. haven't run it yet. too busy with the holidays. well later.
Old 12-27-2001, 06:43 PM   #158
kitracer's Avatar
I don't think any time soon. Most likely is the saddle battery pack layout and harder servo saver available next year, just guessing!
Old 12-28-2001, 09:35 AM   #159
Dragon's Avatar
Send a message via ICQ to Dragon
hey guys, which is supposed to be a better car, the KXone or the Losi XXXS, and why do u say that?
Dragon is offline   Reply With Quote
Old 12-30-2001, 03:26 PM   #160
Default broken kx-one chassis
Have anybody broke kx-one chassis ?
I have two times broke my chassis
Kx-one's chassis seems very strong but have some very weak point.
The from and rear suspension arm holder , the chassis will break from here when have big impact.
It looks like the suspension arms are strong then the chassis ,so the chassis broke.
The under of the chassis all the line are the weak point.
Anyway to strength it ?
Kyosho have a new optional part KXW010 seems to strength something ,but I don't understand japaness (no pic)
Anybody knows?
By the way kx-one's server saver is really too soft.
You can see the wheel direction is what you desired when in a turn.
Must to change it ,you'll feel more direct to steering.( I use dean )
The from onyway , TECH has 6mm oneway ,but I cann't buy it at here.
But you can only buy only oneway bearings to replace ,it is much cheaper (only US.$5 for one) it is made by Germany (INA).
AlexT is offline   Reply With Quote
Old 12-30-2001, 04:20 PM   #161
Anybody knows?
Old 01-24-2002, 07:31 PM   #162
did this die
ttt
Old 01-25-2002, 10:39 PM   #163
seaball's Avatar
no.
Old 01-31-2002, 07:55 AM   #164
boner's Avatar
Anyone have a setup for Kx-one on carpet with foam tire? Or does anyone still run/own this car?
boner is offline   Reply With Quote
Old 01-31-2002, 09:44 AM   #165
ernestf's Avatar
i have still with my kx1, but it is GP season. Havent run it for quite sometimes ....
Top 10 Electric cars ford_racing Electric On-Road 16 04-20-2005 10:03 AM
AE electric cars F/S Turbo9000 R/C Items: For Sale/Trade 1 10-06-2004 09:06 PM
What are the 3 best 1/10 electric cars???? MrRolla Australian Racing 20 04-06-2004 04:48 AM
All About 1/10 Electric Cars cheekeon Singapore R/C Racers 124 01-20-2004 07:33 PM
Stuff for sale Electric 1/10 Cars and Gas cars.. MaxPower R/C Items: For Sale/Trade 0 07-08-2003 09:04 PM
