Old 07-21-2010, 09:55 PM   #1
beginner4life's Avatar
Trader Rating: 9 (91%+)
Default insanely fast on-road car
Im thinking of making a car purely built for speed. I was wondering what yo guys thought would be a good base for making this happen. I was thinking maybe a pan car? Motor suggestions?
*Team Terribles*
RC8T-RB S3-Hitec Servos- Spektrum
beginner4life is offline   Reply With Quote
Old 07-21-2010, 10:52 PM   #2
smilekt's Avatar
sure .. using mamba max pro going to 6S lipo ... go for 2.5T brushless motor .. u will cry ...
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 07-21-2010, 10:57 PM   #3
RDOUBLEDAY's Avatar
lets see how many motors he burns up like that. I say go 1/8 electric car with monster max 2650 on 6s
Mugen Mbx6 Eco .
RDOUBLEDAY is offline   Reply With Quote
Old 07-22-2010, 03:21 AM   #4
Foxxrocket's Avatar
1/10 scale dragster. Built to do one thing... Go vary, vary fast in a stright line.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 07-22-2010, 08:27 AM   #5
I'm not lookin to use a drag car cause I still want handling. I don't have a huge budget so I don't think 1/8 would be the best option. So do you think pan car is my best option?
*Team Terribles*
Old 07-22-2010, 10:19 AM   #6
Foxxrocket's Avatar
It would be the simplest to setup, but you will need good traction with these kinds of cars.
Old 07-22-2010, 11:11 AM   #7
Trader Rating: 17 (100%+)
With todays extreme brushless and lipo power, 4wd is the best way to get power down for insane speeds. Any of the popular touring cars that you can get heavy duty parts for would be the best option. A pan car would be cheap and easy to set up, but will really struggle to put all that power down. The most popular models for speed runs are the TC3/TC4. There are so many option parts available that it is easy to build one of these nearly bulletproof and able to withstand 2-4HP.
I built a TC3 with nothing but steel diffs, and upgraded driveshafts, Mamba Max Pro, Medusa 3300Kv, 5s Lipo, and most importantly, good tires. I only saw 89 on radar, but I know I had several passes not checked that seemed much faster.
Nic Case is the world record holder. I believe his current record is with a Schumacher MI4 that he custom built many parts for. Now he is working on a shaft drive car for a new record shot. http://www.rc-isc.com/forums/showthread.php?t=459
burnineyes is offline   Reply With Quote
Old 07-22-2010, 12:26 PM   #8
I'm really not lookin for a record here or anything I just want something to go reasonably fast. So you think a pan car would be pretty fast? Maybe some weight to help get the power onto the ground?
*Team Terribles*
Old 07-22-2010, 12:50 PM   #9
Foxxrocket's Avatar
I agree, a 4WD sedan is the way to go. But avoid the shaft drive cars. They create major torque steer with motors over 17.5. A belt car is going to run much more smoother at higher speeds. Not only that, but a sedan is going to handle unprepared surfaces far better than a Pan car.
Old 07-22-2010, 01:41 PM   #10
Any specific suggestions? I'll probably buy it used
*Team Terribles*
Old 07-22-2010, 02:06 PM   #11
Foxxrocket's Avatar
TC5 for starters. I know a few guys who have ran this car in speed runs, and hit the 90MPH mark with it.
Old 07-22-2010, 02:17 PM   #12
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
Nic Case's new car seems to be from Associated.
A TC4/3 Carbon fiber Chassi, stretched to a dragster.
The regular things apply again. U need insanely fast motors with crazy torque.
B40 or C40 By Hackers, Lehners and Platinburgs are some of the motors that are used in dragsters. But they go by Scale quater mile and Fast accelaration rather top speed. they can reach 70-80mph in a short distance. rather than reaching top speed on a loooong runway.
So motor wise try looking into Heli motors by the above listed manufacturers. Or something that has alot of Top end and has the powerband sitting at the top end rather the low/mid end. So there are alot different BL powerband motors out there some not form the car world but the fly world
Regular TC motors will get you no where for speed runs since most of them are mid end power
Next thing would be your body and wheels. Body has to be a high downforce body especially the front. at 45-60 mph mark you car will go airbourne with regular TC bodies that includes most of the Rac TC bodies.There are a few bodies that keep steady and dont make ur car start doing jiggy wiggy stuff at high speeds. Different bodies handle different on diff cars with differnet suspension geometry.
Batteries you need some nice High C rated batteries that can deliver the amperage.
Thats about the basics to go fast. There are alot of minor small things in there. but mainly it will depent on ur Wallet size and physics.
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 07-22-2010, 02:42 PM   #13
Not a Dragster hes building there. Its a Streamliner built for very long run-up and high speed. The long wheelbase should overcome most of the torque steer common with shaft drive.
For a nice fast daily driver its hard to beat a plain ol touring car (shaft or belt drive). As long as the car has aftermarket support so you can upgrade axles, belts, diffs, etc. You can build a reliable 60+ street machine with a plain ol Mamba Max 7700 system and a few lipos.
Old 07-22-2010, 03:56 PM   #14
so something like http://www.rctech.net/forum/r-c-item...an-roller.html What would be the issues with this? Not enough weight?
*Team Terribles*
Old 07-22-2010, 05:35 PM   #15
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
What kind of speeds are you looking for? Pan cars can be fast on a well prepared track. I run pro 10 on a track that is blown off with a leaf blower and then sprayed with sugar water to keep the dust down and for traction. With the 2WD pan car a small amount of dust will cause loss of traction and all you will do is very fast donuts. The 4WD cars will have way more traction and are mor forgiving in a parking lot run. With todays programable speedo's the 4WD touring cars can be quite fast even with a 17.5 brushless.
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
1/18 scale ON-ROAD carpet nationals N.Smrt Micro and Mini Scales 334 12-15-2007 09:34 AM
2005 eXpress Paved On-Road Championships Jon Williams Racing Forum 619 06-22-2005 08:30 PM
