2100Mah Lipo
Old 07-20-2010, 06:35 PM
Default 2100Mah Lipo
Do you think I could get a 6 min heat out of one? I am running RCGT, 27turn stock. I ask because I am seeing them pop up for very cheap, figured a couple charged up for the heats wouldn't be bad and use the 5000mah in the main.
Chip73 is offline
Old 07-20-2010, 06:40 PM
mpboost's Avatar
There are several unpredictable factors that will effect your run time. Your best bet is to try out a 2100mAh pack during practice and see if it will make 6mins at full pace.
I know where I race, with my car setup, that I always end up putting around 2100mAh back in my 5000mAh Thunder Power packs.
mpboost is offline
Old 07-20-2010, 06:54 PM
taco94's Avatar
Well, mpboost is right about practicing. But just to be safe, look into at least 3000+ mAh batts. Reedy makes a 3200, 20C for something like $60, I believe.
taco94 is offline
Old 07-20-2010, 07:00 PM
I have several 5000 and 5400 lipos, but for $14 shipped seemed like a decent price. Maybe I'll grab one and give it a whirl.
Chip73 is offline
Old 07-20-2010, 07:52 PM
I only use about 1900mA in my TC with a 13.5 brushless in 5 minutes. It's on a large outdoor track, so not quite the current-draw you can get on small tracks. Is it a silver can, or pro-stock type motor?
I'd say silver can no problem, pro-stock may be touch-and-go.
JR007 is offline
Old 07-20-2010, 07:58 PM
Regional Moderator
CarbonJoe's Avatar
If you're on a budget, just get some hard case Turnigy 5200 mAh packs from HobbyKing.com. They're $23 per pack. Shipping is relatively expensive, though. They've been working great in my Slash 4x4 with a Novak 4.5 motor (used 4600 mAh in a 10 minute main).
CarbonJoe is offline
Old 07-20-2010, 10:08 PM
Xmod_Racer's Avatar
these packs weigh a TON. I'd try the yeah racing 3200 packs. About $30 dollars per pack
Xmod_Racer is offline
Old 07-21-2010, 06:22 AM
Money is not the issue or weight. I just am starting to see these packs popping up for 9.99 plus 4.99 shipping, with multiple purchases I can combine shipping. Just wondering if they are worth my money.
Chip73 is offline
Old 07-21-2010, 06:33 AM
Heats are most important, better go for one good 4000-5000 battery that you can charge 2C or 3C then a few 2000 or 3000mah. At the end you will end up with 5000 one and you will not use cheap ones at all.
You will have balance problem as 2000 packs are half the weight of 5000 packs.
So if you have money limit go for one good 4000-5000 pack and save a little to get second 4000-5000 pack.
tomislav is offline
