Mixing Silicone Oil >
Mixing Silicone Oil
Mixing Silicone Oil
Old 07-20-2010, 05:23 AM
LOSI123's Avatar
Trader Rating: 63 (100%+)
Default Mixing Silicone Oil
I wanted to know if there is a formula for mixing oils.
Say if i had 1000wt diff oil & 5000wt diff oil and i mixed them what other wt's could i get, and what amount of each would i need to get what numbers. any help would be good, thanks
I am wanting around 2000wt if posible.
the reason is i wanted to try it out tomorow, and no one local to me has it.
LOSI123 is offline
Old 07-20-2010, 06:00 AM
chicky03's Avatar
http://www.gelest.com/company/pdfs/siliconefluids.pdf
Page 26 will show you a chart and formula. 2000 cst is pretty widely used, Kyosho, Mugen, Xceed, Serpent, and Xray all sell it.
chicky03 is offline
Old 07-20-2010, 06:06 AM
[[john]]'s Avatar
Trader Rating: 24 (100%+)
If all you require is 2000wt, just mix 1000wt with 1000wt.
[[john]] is offline
Old 07-20-2010, 08:14 AM
musti72's Avatar
3 drops 1000wt and 1 drop 5000wt would do an 2000wt.
musti72 is offline
Old 07-20-2010, 09:37 AM
That is a frickin' rad post! I have never though of mixing oils to get different weights of oils... !
rcnewb2004 is offline
Old 07-20-2010, 04:23 PM
The only thing you ahve to check, is "weight" is not a linear scale, and varies between manufacturers. "cst" is a linear scale and would be the ideal choice for mixing proportions, e.g. 50/50 mix of 1000cst and 3000cst will give you 2000cst.
JR007 is offline
Old 07-21-2010, 03:41 AM
LOSI123's Avatar
What brands have a good reputation of using accurate cst ratting and sell diff oil?
I use much more shock oil which i think might be cst but they dont seem to have higher numbers for diff's , i dont think.
LOSI123 is offline
