F1 Conversion kit from Yeah Racing >
Old 11-03-2010, 10:30 AM
  #31
Vyger's Avatar
Thumbs up
Originally Posted by InZane View Post
Damn InZane, you do good…I mean excellent work. Nice build and nice pics of the progress. I’m anxious to see the ESC mounted and wired. It doesn’t look like there’s a whole lot of room for the electronics. Keep us posted.
Vyger is offline
Old 11-03-2010, 01:09 PM
  #32
InZane's Avatar
Thanks,
My Xtreme Stock ESC fits like it was purpose built for this chassis
Attached Thumbnails F1 Conversion kit from Yeah Racing-tr_1e.jpg   F1 Conversion kit from Yeah Racing-tr_1f.jpg
InZane is offline
Old 11-03-2010, 03:32 PM
  #33
Vyger's Avatar
NICE!!! It fits like a glove. By the way, I like your website too. I wish I could read it.
Vyger is offline
Old 11-03-2010, 08:30 PM
  #34
InZane
Could you please tell me if that servo mount will fit directly into a F109, If so i will have to keep my eye out for them when they become available by them self's. Just what i have been looking for.
Cheers, and keep up the great builds and reviews.
HandS is offline
Old 11-04-2010, 03:11 AM
  #35
InZane's Avatar
Originally Posted by HandS View Post
InZane
Thanks - unfortunately it's not a direct fit, mounting holes are closer on this one.
InZane is offline
Old 11-04-2010, 05:08 AM
  #36
Missle's Avatar
Your conversion looks GREAT! Couple questions, is there an advantage to running the battery long ways like you've done versus placing it width wise?
Second, will this kit be a direct fit replacement for a tamiya f103gt frame (ie front end, rear end)?
Missle is offline
Old 12-15-2010, 07:26 AM
  #37
InZane's Avatar
Ready for track testing ...
InZane is offline
Old 12-15-2010, 07:30 AM
  #38
gashuffer's Avatar
Trader Rating: 48 (100%+)
Have you tried the T plate config yet? A friend of mine runs this car( T-plate) and it's hooked up.
gashuffer is offline
Old 12-15-2010, 07:45 AM
  #39
InZane's Avatar
No - I decided to build it as a link car from start.
Maybe I will try the T-bar version for my back up chassis.
InZane is offline
Old 12-15-2010, 11:51 AM
  #40
What's with the wide spacing on the rear axle?
InspGadgt is offline
Old 12-15-2010, 01:07 PM
  #41
InZane's Avatar
We are using Tamiya F104 Rubber tires as control tires for the Swedish F1 winter Cup. The spacing is used to make the rear wider as we're having big problems with traction roll when running the narrow rear end.
InZane is offline
Old 12-15-2010, 02:12 PM
  #42
Makes sense...are you then using an F104 rear pod to get the right height correct?
Old 12-15-2010, 10:26 PM
  #43
InZane's Avatar
Yes you can use the F104 motor pod - it's a direct fit but chose to stay with the original pod as I like the design/looks of it.
I use a 3Racing 3mm shim motor mount for the F103GT (F103GT-25/WO) sandwiched between the pod and the carbon motor plate. Ride height is 4mm - same as if I use the F104 motor pod.
InZane is offline
Old 12-15-2010, 11:22 PM
  #44
InZane's Avatar
If you can't fit your electronics on the chassis plate between the links and the lipo a nice solution is to mount a 3Racing Graphite Radio Tray for M05 (M05-11/WO).
InZane is offline
Old 12-16-2010, 11:02 AM
  #45
Cool...didn't know 3Racing made a part specifically for the ride height...would have saved me having to cut one for my F1-09.
