Old 08-16-2010, 12:43 PM   #121
We're picking and packing as fast as is humanly possible, I'm on a tea break now, been in work since 6.45am. If it didn't catch the post today it will tomorrow.
jonrg is offline   Reply With Quote
Old 08-16-2010, 01:32 PM   #122
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I really want to try a set of these on the front of my car but after running the mi4 with aluminum axles they always bent. Are these stronger?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 08-16-2010, 01:49 PM   #123
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Originally Posted by jonrg View Post
The material we use is L160 which is the aerospace & defence release version 7075T6 which is ultrasonically tested for any impurities and is generally used by them in high stressed areas..
From all the testing we think they are brilliant so much so we offer a warranty
Hanging out with the real rock crawler people, I learned 7075T6 is supposed to be a flexible material. If it flexes, it will flex back to its original shape. They use it for 4 link suspensions to get flex, and flex back.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 08-16-2010, 02:15 PM   #124
How do these joints handle a dirty track?
If they're open and packed with grease do they bind if run in less than perfect conditions where small bits of grit could stick to the grease and potentially work their way into the joint?
spongerX is offline   Reply With Quote
Old 08-17-2010, 12:12 AM   #125
Airwave's Avatar
Have you planned to make some stainless steel front kit?
Airwave is offline   Reply With Quote
Old 08-17-2010, 02:45 AM   #126
Gav-'s Avatar
Ordered some T3 ones yesterday. Will run them shortly and share my experience!
Gav- is offline   Reply With Quote
Old 08-17-2010, 05:25 AM   #127
Skiddins's Avatar
Jon, whats the purpose of the rubber bit that has to be installed?
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-17-2010, 05:45 AM   #128
TheCoolCanFanMan's Avatar
Skiddins
Hi Damo
You need to cut the rubber and put a piece into ur outdrives to reduce the movement of the driveshaft to aprox 1mm wen in situ
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 08-17-2010, 06:33 AM   #129
Skiddins's Avatar
Originally Posted by TheCoolCanFanMan View Post
Hi Damo
Cheers Malc
So it is to stop the 'dogbone' section from moving further into the axle, which would make the driveshaft blades start to come out of the diff cups?
Err, does that make sense?
Skiddins
Xray X12 2018
Xray X1'16
RCDisco.co.uk
Old 08-17-2010, 07:22 AM   #130
Damien, the "backlash" adjustment is done with the blades already attached to the dog bone. It does become pretty obvious when you set them up. With each set we do give a very detailed setup guide and diagram.
Hope that makes sense
Jon
Old 08-17-2010, 08:03 AM   #131
Skiddins
Yea, its to take up the shaft float, so the shaft don't go in n out.........that's just sounds wrong lol
Cheers Malc
Old 08-17-2010, 08:14 AM   #132
JCarr's Avatar
A good question that seemed to get skipped. Are there any plans for a boot to go over the joints?
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 08-17-2010, 02:45 PM   #133
erchn's Avatar
Have the CVS orders shipped? My order status hasn't changed from "picking".
erchn is offline   Reply With Quote
Old 08-17-2010, 03:29 PM   #134
+1
Zen RSGT, Trinity, Hobbywing, LRP.
M05 S-Spec, LRP, Intellect.
M05 v2 Tekin, Orion, Savox.
B44 Mamba Max, Trakpower.
B44.2 Avid chassis, Speed Passion, Gens Ace.
BILKO1 is offline   Reply With Quote
Old 08-17-2010, 04:45 PM   #135
I'm hoping the rest of the orders will be dispatched tomorrow, we've just been snowed under and carefully building each CVS does take a bit of time.
With regard to boots we are looking at various options, but really haven't cracked that nut yet.
