Old 08-01-2010, 03:10 PM   #76
Originally Posted by jonrg View Post
Thanks, Wingracer you beat me to it
Thanks for that, Jonrg do you have them in stock or do we pre order them and wait for stock to arrive ?? I thinking of ordering a front pair for my T2 009
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 08-01-2010, 03:19 PM   #77
They are on pre-order. We will be dispatching 15th August.
jonrg is offline   Reply With Quote
Old 08-01-2010, 03:46 PM   #78
DS Motorsport's Avatar
If you only use them at the fronts (in a NT1) will the car have more steering?
And what for material are the NT1 shafts made off, because with my new engine I started breaking the hudy steel cvd's in the rear.
Currently using dogbones, they seem to hold up.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 08-01-2010, 06:50 PM   #79
JamesReilly's Avatar
Trader Rating: 58 (100%+)
What lengths will the photon ones be? 46 / 44.5 or 46 / 44?
Thanks,
James
Reilly Paint ([email protected])
JamesReilly is offline   Reply With Quote
Old 08-02-2010, 01:59 AM   #80
Default Currency Conversion
Ok, I've sorted out why there is a price difference. The UK price is 87.96 if you convert that to dollars it comes out at about $138, but the UK price includes VAT. For the US market we are not allowed to charge you guys VAT so we have to take 17.5% off the UK price, if you then do the conversion it comes out at $110.74.
So when you order make sure you use the correct currency, there is a check box at the top of the page for different currencies.
Old 08-02-2010, 02:28 AM   #81
Gav-'s Avatar
Please tell me you can ship to Aus
Gav- is offline   Reply With Quote
Old 08-02-2010, 02:58 AM   #82
Benzaah's Avatar
Trader Rating: 21 (96%+)
X2. Even if i have to pay in Us dollars i want some of these.
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is online now   Reply With Quote
Old 08-02-2010, 03:04 AM   #83
Yep, we'll ship just about anywhere.
Old 08-03-2010, 04:00 AM   #84
DS Modelsport you have a PM
Old 08-03-2010, 04:54 AM   #85
For the TC5 CVS axles your description has "This will require an Xray Hex to complete."
Is the Xray Hex being referred to the Aluminum wheel hub that the wheel mounts to?
Do the Associated TC5 CVA plastic blades fit on the end that connects to the diff or should Xray blades be used for this?
spongerX is offline   Reply With Quote
Old 08-03-2010, 05:51 AM   #86
The axle has been changed to use an Xray hex, normal TC5 steering hubs and normal TC5 blades. The reason for this is that it uses a 2mm hex drive pin rather than a 1/16th and the shaft diameter is 4.94mm rather than 4.0mm.
Old 08-03-2010, 06:02 AM   #87
UK.hardcore's Avatar
1/8th scale, will it be on-road or off-road or both?
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 08-03-2010, 06:20 AM   #88
We're working towards both, but it wll be a while yet before anything else is released.
Old 08-03-2010, 06:59 AM   #89
Skiddins's Avatar
Just a note for the Xray owners.
The 'Front's' appear to be equivalent to the 52mm driveshafts and those on the Litemodz site as 'Rears' are 50mm
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-03-2010, 07:10 AM   #90
Damien, we do a 52mm or a 50mm Front and a 50mm Rear
