Litemodz CVD
#497
Quick question, am I going to get screwed around again and again cause I live overseas, and although I have basically bought the product twice due to having to ship it back 4 - 5 times have still ended up with a set of broken driveshafts?
#500
#504
Trader Rating: 22 (100%+)
must see if your interested in buying this cvds
http://www.youtube.com/watch?v=UEvaOg7glKk
We need tri lobe CV joints, they will be good enough.
Or a chunkier Double cardan joint.
#505
Had a set of the first series in my mi4, broke them outdoors without hitting anything..
How much have they improved over the last 11 months? with this new evo2 steel design?
I don't crash often with my t3 2011, but sometimes will clipa wheel, would this bend or break them as easy as the original design ones did?
Cheers.
Cheers.
#506
I have around 1500 laps done with the evo2 on indoor high grip carpet. The car is equipped with 17,5t unboosted electronics at 1400 grams. I had some hits in the wall also. Up till now the cvs work flawless. No vibration, a smoother turn in with the spool, no such resistence effect like it is shown in the Thompson video.
Therefore I am not 100% convinced with the product quality, because two of the four ordered cvs tend to bend slightly at around 20° angle. I put them in the back where they can't make any trouble. The material itself now looks strong enough to withstand modified...
This is what I wrote more than two months ago in the TC6-Thread:
Yes, I bought them. I know everyone who read the Litemodz thread now maybe thinks I must be a little confused and just two weeks ago I would have said you are right. It just took 5 weeks and three reminder emails until I got the first packet. Now you will ask yourself why the first. Just because they forgot to ship the inner cages of the axles. It then needed another week until I got them.
Today I could finally assemble these special axles. And it was &
I ordered four axles. After assembly two are smooth as oil and two are bending when simulating steering. I couldn't solve the problem, so I use them for the rear. The assembly itself went fine without any problems. Everything fits without play.
The next problem occurred when I tried to put on the blades. The bonepins are 1.99mm in diameter. So the blades get on, but bind. Second thing the boneend is to thick. The bladeholes have to be widened and the inner blade U has to loose some material, too. Very frustrating for a product of this price and supposed for a TC6...
The next shock came when I installed it at front. It fits good, but I could not steer, because the end of the axle towards the C-hub stands out to far and has a greater radius than the originals. At this time I really wanted to throw everything in the corner and send this garbage back to the rainy place it came from! I could calm myself and analysed the problem. The C-hub need to get a 2mm radius around the oval opening edge in the middle and then the axle can move free. After that the rest of the installation went fine.
The first dry test was satisfying. No chatter at all even with full steering angle. Unfortunately the last indoor race of the season is history already and I don't know if it makes sense or will be faster on asphalt...
In conclusion Chris from Litemodz was very kind and seems to be interested in customer satisfaction. On the other hand when telling me he will send the order out the same week it was in fact two weeks later (the Royal mail just took three days to deliver). So I got the impression that the parts weren't available until I got them. All these things leave a mixed impression. Time and racing will tell if I turn out to a regular customer.
OK, thats all I have to say now. I think you guy deserve some pictures for reading:
#507
Thank you for the informative reply
#508
good results so far
Hi,
I'd like to chime in. I have been running the latest steel version in my Xray, since the carpet Nats at Timezone this year, I was able to get a set from Warren that arrived the day I was leaving. I built them that morning, and have had no problems so far. I cleaned and repacked them since, and that is all they have needed. Just ran yesterday outdoors for the first time in a bit, and they held up fine. I will continue to report back any info.
-Alex
-Alex
#510
I think dirt is the real enemy of this design!!! Losi LCD's design don't have that problem, and they can be made to fit any car ( tc4/ tc5/tc6/ntc3 ...etc...).......
