Old 07-27-2010, 05:19 PM   #31
Hi Damien, all will be revealed next Monday.
jonrg is offline   Reply With Quote
Old 07-27-2010, 06:34 PM   #32
Well I've been waiting for Stormer to get Corally parts in so I can replace the MIP CVDs it comes with...but if the Litemodz ones will be compatible I would rather get them...soon.
Old 07-27-2010, 08:24 PM   #33
vabroom's Avatar
Jonrg,
Will the bones be interchangeable? What I'm trying to said, there a few of us that use a different length bone than what came with the car kit.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 07-28-2010, 01:37 AM   #34
darrenoakley's Avatar
Roll on Monday, interesting to see what they will cost.
Xray x11
Xray T3 011
darrenoakley is offline   Reply With Quote
Old 07-28-2010, 06:27 AM   #35
Originally Posted by vabroom View Post
Jonrg,
If you require a specific length which is "common" to the make you require we should be able to accomodate you. What we won't be able to do unless you want to pay a premium is make "Taylor made" lengths.
Also front and rear axles won't be interchangeable.
What are you running at the moment?
Old 07-28-2010, 06:40 AM   #36
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
I think he was reffering to different length bones, as with a tamiya for example, you can run 42/44/46mm bones, but on the site it doesn't mention what length the bones are.
If that makes sense
thanks
luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 07-28-2010, 08:14 AM   #37
Thanks Luke, I've edited my original post.
Old 07-28-2010, 12:24 PM   #38
M-Technic's Avatar
Trader Rating: 15 (100%+)
What the bones made from? Titanium, right? How is the strength and weight versus what we normally run on Tamiyas (steel in the front, aluminum in the rear)?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 07-28-2010, 12:35 PM   #39
vabroom's Avatar
If that makes sense
thanks
luke
Thanks for making sense for my bad grammer.
Old 07-28-2010, 12:49 PM   #40
musti72's Avatar
Nice, looking forward to it.
I couldnt understand how this system would help about tire wear... any ideas?
Can you guys measure the weight of the one axle and one driveshaft for the NT1?
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 07-28-2010, 06:36 PM   #41
vabroom's Avatar
Right now I raced a Photon. Depending on how you set up the rear diff, you use either a 44.5mm bone or a 46mm bone. The same situation can happen in the front end. A litemodz spool will use a certain length bone and a gear diff will use a different length. It would be helpful to know what lengths are available.
I am definitely want this cvd! I just want to be able to adjust to different track situations.
Old 07-28-2010, 06:45 PM   #42
Even that might change with the Litemodz...depending on the spacing of the joint compared to the stock one may change the length of the bone needed.
Old 07-28-2010, 08:19 PM   #43
vabroom's Avatar
That maybe so, but with the listing of bone lengths you should be able to figure out which one you need.
Old 07-29-2010, 03:42 AM   #44
Musti, you have a PM.
Old 07-29-2010, 04:32 AM   #45
musti72's Avatar
PM replied.
Mustafa Alp
