Old 09-25-2010, 01:11 PM   #286
Send a message via MSN to 9vut Send a message via Yahoo to 9vut
Today i test CVS is very good
9vut is offline   Reply With Quote
Old 09-25-2010, 04:24 PM   #287
Impulse_racer's Avatar
I have had the V1 CVSs front and rear on my T3 for about 4 race days and a few practice days. I run mostly 10.5 Sedan. I'm an average driver which means I hit stuff, and stuff hits me, and on occasion my T3 becomes a stunt car or model airplane. My point is that I am not in the top 10% of racers who love this hobby. My CVSs have held up brilliantly. No failures of capture rings or anything else. There is a very slight bend in the left side front bone but the abuse it took to slightly bend it would have required a replacement of the Xray part. Other than that they look just as they did when I got them in the mail. I haven't recieved the V2s but I am very happy with the V1s.
Xray T3 EU
KO Propo Helios
Tekin RS Pro/LRP X-12/Venom LiPo
Hudy
Litemodz CVS
Impulse_racer is offline   Reply With Quote
Old 09-25-2010, 04:57 PM   #288
Impulse you have PM
jonrg is offline   Reply With Quote
Old 09-25-2010, 09:27 PM   #289
RCknight's Avatar
Default Jon I'll buy a set right now if you can post some updates.
Has the design changed much from the old pics?
RCknight is offline   Reply With Quote
Old 09-26-2010, 09:57 AM   #290
RC Knight, the basic design hasn't changed, just details on the internals.
Old 09-26-2010, 06:06 PM   #291
Trader Rating: 25 (100%+)
What kind of grease are you guys using to re pack the CVS after running them?
matt rem is offline   Reply With Quote
Old 09-26-2010, 10:54 PM   #292
And how often do they need re-packing?
I like stuff that's fix-o-dent and forget it... at least until I break it.
-Mike
Old 09-27-2010, 02:04 AM   #293
Gav-'s Avatar
Since there is no cover on the shaft, I'm rebuilding mine every week.
I just use ZX1, and thrust bearing grease.
Gav- is offline   Reply With Quote
Old 09-27-2010, 03:01 AM   #294
PizzaDude's Avatar
Do you mix 'em or apply each on different parts?
PizzaDude is offline   Reply With Quote
Old 09-27-2010, 05:35 AM   #295
Gav-'s Avatar
Clean them out. Add the ZX1 to the balls. Put a little bit of grease in the cup, put the shaft back in and add some grease to the top. Make sure it runs freely.
Repeat!
Old 09-27-2010, 06:55 AM   #296
I use a graphite based synthetic grease. Thick but slick. Every other race day, which may include a practice day in between, I spray them clean with a motor spray and repack. I do not think there is a need disassemble them unless you are doing a rebuild. Just put a blob of grease in the joint and use your finger to push it down into and behind the cage. Move the axle around to get the grease everywhere it should be and to check for continued free play. You don't have to fill the whole cup of the axle. The excess will spin out the first laps anyway.
A quick tip for those like me who were curious how these things work and did take it appart. The little balls bounce real good and like to play hide and seek. If you lost one or two, I found that the diff balls from my T3 are the same size and caused no binding. This will work until you get a proper rebuild kit.
-Mike
Xray T3 EU
KO Propo Helios
Hudy
Litemodz CVS
Old 09-27-2010, 07:57 AM   #297
Senna Racing's Avatar
were can i get these from as there website doesnt seem to work
Feral Batteries for all your on road needs
TRF 416, Fantom Batteries, Sorex, Tekin
Senna Racing is offline   Reply With Quote
Old 09-27-2010, 02:02 PM   #298
They arrived thanks Litemodz.
Zen RSGT, Trinity, Hobbywing, LRP.
M05 S-Spec, LRP, Intellect.
M05 v2 Tekin, Orion, Savox.
B44 Mamba Max, Trakpower.
B44.2 Avid chassis, Speed Passion, Gens Ace.
BILKO1 is offline   Reply With Quote
Old 09-29-2010, 12:49 PM   #299
jag88's Avatar
What's happening with these guys ? Web site has been down a couple of days.
jag88 is offline   Reply With Quote
Old 09-29-2010, 12:52 PM   #300
Fred Hubbard's Avatar
Originally Posted by jag88 View Post
Are these guy's still around ?
Of course they are!!!
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
