Old 05-29-2004, 03:56 PM   #1
Brandon Krell's Avatar
Send a message via AIM to Brandon Krell Send a message via Yahoo to Brandon Krell
Default Degreasing Bearings
this forum is about degreasing bearings, all types, meatl sheilded, teflon, rubber, and all the other types, please post all your tricks of the trade on this topic.
Brandon Krell is offline   Reply With Quote
Old 05-29-2004, 04:04 PM   #2
NVisible's Avatar
I remove the seals and throw them in lighter fluid over night.
change the fluid the next day for clean stuff and let them soak until i get off work. (8 hours or so)
I use Rollerblade bearing lube in mine, but im sure theres better stuff to use
NVisible is offline   Reply With Quote
Old 05-29-2004, 04:10 PM   #3
the Acer Racing stuff is great, I will put mine in Motor spray for about an hour or so, then line them up and put some oil on the outside of the sheild, and let it soak in, the sheilds stay on the whole time, a sheild that has been taken of will never hold the same, it will always hold worse
Old 05-29-2004, 07:56 PM   #4
Well....
Just dont do this.....
Don't put them in laquer thinner at the end of the year and forget about them.
ummmmm I have a container that has them all rusted together and now18 bearings are ruinend lol.
Smalls is offline   Reply With Quote
Old 05-30-2004, 07:07 AM   #5
Robfo's Avatar
I use brake cleaner from an aerosol can with an RPM bearing blaster. Then re oil with Acer racing oil
Robfo is offline   Reply With Quote
KANZEN Bearings vs Boca Bearings vs Other Bearings rmdhawaii Nitro On-Road 6 04-29-2006 09:38 AM
TC3 Bearings Ridge_Racer Rookie Zone 17 12-22-2005 09:16 PM
Dry bearings mcc-bri Electric On-Road 29 01-31-2005 12:49 AM
Next Best Bearings To Ceramic Bearings????? J Smith Electric On-Road 47 08-21-2003 03:26 PM
degreasing bearings sportracer Electric On-Road 3 05-06-2003 09:34 AM
