Old 12-23-2010, 04:21 PM   #16
rc_square24's Avatar
Anyone tried their tires on the regular rims? The see-though-ish rims are kind of weak, wondering if the non-lightweight ones are any better.
rc_square24 is offline   Reply With Quote
Old 12-23-2010, 06:08 PM   #17
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
The non-lightweight Exceed are made by Jaco,
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-23-2010, 09:00 PM   #18
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
The wheels or the foams?
Old 12-23-2010, 10:13 PM   #19
About 9% sure the bx they cme in is the nly difference.
Old 12-23-2010, 11:34 PM   #20
So you mean both wheel and foam is Jaco?
What compound is the medium carpet equivalent to Jacos? And compared to the foams on lightweight wheels?
So are the regular wheels stronger or not? I have never used Jaco tires/wheels.
Old 12-24-2010, 05:01 AM   #21
chicky03's Avatar
Send a message via AIM to chicky03
The tires that are graded in soft,med, hard etc are the ennetti/xceed version, tires that are graded in colors just like jaco are the jaco/xceed version.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 12-24-2010, 11:11 AM   #22
Danny-b23's Avatar
Does anyone have some general shore guides for the Xceed tires so they can sort of be compared to the Jaco and CRC tires?
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 12-24-2010, 01:36 PM   #23
Exceed tyres come on standard (white) and lightweight (see-through) rims. The white ones are heavier, and possibly, a bit stronger. I've cracked one lightweight rim, but that was a hard hit and all my fault.
Comparing Shore hardness won't help as the Exceed compounds are quite different. Use the Exceed tyres for what they are, and not for how they compare. They are a more stable tyre than Jaco yellow and pink, so they can be used at larger diameters and still give good handling.
I find they have more grip than Jaco although they are harder. Exceed tyres are probably one or two tenths a lap slower (according to my tame top-ten driver!) than Jaco, but I find them more consistent and easier to drive. Quite a few people I race with have switched to Exceed and are getting better wear, less chunking and more consistent grip. Medium both ends seems to work for me when the grip is up, soft rear when it's gone missing! HTH
SlowerOne is offline   Reply With Quote
Old 10-16-2011, 06:54 AM   #24
Do the wheels work with non-flanged bearings? I am ordering the tired just need to be sure I don't have to order bearings.
Mr Granone is offline   Reply With Quote
Old 10-16-2011, 07:10 AM   #25
fatbear's Avatar
Send a message via Yahoo to fatbear
Are these tires only for carpet or are they good on asphalt as well?
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 10-16-2011, 01:01 PM   #26
Julius's Avatar
There is a carpet and an asphalt version.
The lightweights are no longer produced. Now only regular and carbon rims.
Do check trackwidth as the offset is slightly different from jaco.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 10-16-2011, 01:35 PM   #27
The latest ones I bought (this month) work with either flanged or unflanged bearings. I've got the latest black wheels, which are sooooo much better than the lightweight (opaque plastic) rims.
Providing that they are the latest black rims, they take either type. However, be aware that if you use two flangeless bearings they will need a spacer between the wheel and the wheel nut on the front axle of a 12th car, as they will leave some of the unthreaded part of the axle exposed! HTH
Old 11-21-2012, 02:17 PM   #28
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
any recent opinions on these? Looking to pickup some tire sets for a CRC 1/12 XL . Don't know much about 1/12 as far as flanged, unflanged bearing stuff as it pertains to that model (don't have it apart yet.)
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 11-21-2012, 08:11 PM   #29
I recently tried them out at our track. Grip has been fairly low lately in general and these tires felt at least as good as the other tires I was running given the low grip the track had. For how much less expensive these are than other tires I think they are worth it. The only issue I've had with them is the truing...the fronts are bigger than the rears and they really were not consistent in diameter. You'll definitely want to true them before running them.
Old 11-22-2012, 06:14 AM   #30
Default Xceed Tyres
I have a good few sets that I want to sell as I no longer run 12th, I you have any interest email me [email protected] they will be going cheap!!!
kdempsey is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46184 Yesterday 09:37 AM
Xceed tyres 1/12 carpet CivicTuning Electric On-Road 13 12-10-2010 12:02 PM
Xceed US, Japanese and Italian Foam FranQBs Nitro On-Road 31 07-04-2009 11:04 AM
