TC Handling Question >
Old 07-10-2010, 09:16 PM
KDagh1's Avatar
Default TC Handling Question
Hi -
I was racing my EVO III Surikarn today on an outdoor unsealed parking lot (highly abrasive). I was using Sorex 36Rs (I think) and treated them with TQ Traction Compound. Also, running a 13.5 brushless and SMC LiPO. The package worked extremely well, however the rear wanted to step out under power coming out of corners.
I tried switching to softer rear springs. It helped a little bit, but the problem was still pretty bad and I had to be gentle getting it around the track. What should I try next?
Thanks in advance,
Khal
KDagh1 is offline
Old 07-10-2010, 11:48 PM
Trader Rating: 37 (100%+)
What is your rear toe in set at? Try 3* if it already isn't there, you could also adjust the front downstops so the front comes up more. Basically try to get more weight transfer to the rear.
chensleyrc1 is offline
Old 07-11-2010, 08:04 AM
KDagh1's Avatar
Thanks. I think my rear toe-in is set at 3.5, but I'm not sure. I'll have to double-check it. Why would that affect rear traction? The front downstops adjustment sounds like a great idea. I'll give that a try. Thx.
KDagh1 is offline
Old 07-11-2010, 09:08 AM
I personally never use more than 3 for rear toe, the rear toe in makes the rear more stable. Something else you could try is adding squat to the rear.
Here is a set-up guide from the T3, the concept is the same for all cars though. Just clik the link and scroll to the set-up guide.
http://www.teamxray.com/teamxray/pro...ria=0&catName=
