Belt Morphing?
Old 07-08-2010, 11:38 AM
Default Belt Morphing?
I was wondering if it is possible to maybe morph 2 belts togethor to make a longer belt.?
boblawblaw is offline
Old 07-08-2010, 12:29 PM
niznai's Avatar
You mean like through a wormhole to a parallel universe?
How long a belt do you need? There's quite a few really long ones available for cars with single belt setups.
niznai is offline
Old 07-08-2010, 12:52 PM
Foxxrocket's Avatar
Don't bother trying to make one large belt from two other belts. You'll end up with two useless belts. Like Nazini suggested buy one belt that will fit the car.
Foxxrocket is offline
Old 07-08-2010, 08:45 PM
JKL1031's Avatar
one useless piece of two belts
JKL1031 is offline
Old 07-08-2010, 09:56 PM
BadSign's Avatar
Trader Rating: 15 (100%+)
I think it only works if you buy "Power Ranger" brand.
BadSign is offline
Old 07-08-2010, 10:07 PM
Radio Active's Avatar
Is this for your RC car, or have you just put on a lot of weight recently?
Radio Active is offline
Old 07-08-2010, 10:16 PM
JKL1031's Avatar
seriously, what kind of car.
JKL1031 is offline
Old 07-08-2010, 10:43 PM
V_28's Avatar
hmmm... I don't think it will work for an RC car because whatever method you try to connect the two belts, the joint won't hold with all the rpm's a motor places on it. That's a whole lot of friction.
V_28 is offline
Old 07-09-2010, 12:09 AM
HB Moose's Avatar
Think outside the RC box. Most of the belts are 3mm wide with 3mm pitch. you figure out what size you need an find an industrial supply that sells belts. In school it was called design by catalog.
HB Moose is offline
