Old 07-09-2010, 07:36 AM   #16
Jochim_18's Avatar
Throw a carpet down that will solve your traction issue
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 07-09-2010, 07:42 AM   #17
Originally Posted by Radio Active View Post
Ok, yes, there might not be enough grip for anything sensible. Magic might be the best option. But let's assume that someone actually sells something that will work. Can we try and complete this sentence:
If anything will work it will be _________.
CARPET !
CPD Racing
chris_dono is offline   Reply With Quote
Old 07-09-2010, 10:25 PM   #18
Many years ago(25+) foam tires coated with silicone caulk and grooved with a comb with of all things Triflow sprayed on the track seemed to work well. This was pre-differential era. However, it sure made it hard to play basketball the next day on the surface!
alphacat is offline   Reply With Quote
Old 01-28-2011, 03:54 PM   #19
Radio Active's Avatar
Can anyone give me some more tips for applying the silicone caulk? How much foam should be left on the tyre the caulk is applied to? Does the compound of the foam make much difference? How thick should the caulk be? And how important is the grooving/tread pattern?
Reigning NSW 4WD Group 20 Champion
Member: Maitland Radio Car Club (http://www.morcc.com.au)
twitter: @dvcotton
Australian 12th Scale hastag: #EP12AU
Radio Active is online now   Reply With Quote
Old 01-29-2011, 08:31 AM   #20
mxrich's Avatar
Do not for any reason go to silicone for hard surface racing. You will have the stuff coming apart all over the place. You have two ways to do this. Get some asphalt sealer which rc cars cannot run on. Then put a bunch of sand in the mix and spread it over the track. Spray the track the day before the race (very important) and you may get a season out of it before recoating but it still may not give the traction you want. Do a small test first. Slicone will work if you are racing on smoot dirt like a clay oval or, a basketball court. It works great there. The best option for concrete would be to run cars that have rubber tires. Touring, F1, rally, Mini's etc. Or find a church with a nice asphalt lot and have races on saturday.
I park faster than most people drive.
mxrich is offline   Reply With Quote
Old 01-29-2011, 08:43 AM   #21
mxrich's Avatar
Everything I know I learned from alphacat. He's been around for a while and was the first sponsor of the cave 3 Neanderthal Nat's. He was beating some girl with a club the first time I saw him. She married him and they are still together. But now she has two German Sheperds to keep an eye on his F1 racing self.
Hey! are we ready for the Texas F1 race!
Old 01-31-2011, 07:42 PM   #22
I don't have any ability to modify the surface, nor am I buying another car. I really just want tips for how thick the silicone should be etc.
twitter: @dvcotton
Chua Chu Kang Radio Control Modellers Club Superboy Singapore R/C Racers 977 05-16-2007 06:12 PM
