Team Associated TC6 Thread >
Like Tree20Likes
Old 01-09-2011, 03:09 PM
  #1396
jackdani's Avatar
just a couple of shoots of my FIRST track test!
the tc6 looks more than nice and easy...i found it a very responsive car, regulation and setup is easy and you always have a clear reaction from the car..this is what i felt even if i m little more than a beginner.
the track condition were absolutely bad...humid-nogrip-aspalt..but even here the car worked well...cant waint to test it on carpet or grip asphalt..i have the feeling that it will be "glued" on the ground...won't it??
and here they come..
on the pit waiting for power...
details are also important...
in action...
and finally the new body...
jackdani is offline
Old 01-09-2011, 03:28 PM
  #1397
slicendice's Avatar
Trader Rating: 23 (100%+)
hello new to touring cars I have just started playin around with my tc6 and wanted to implement Keven Herbert Timezone setup that i found on petit rc
I have a couple questions about the setup That I was wondering if anybody could help me with
1.Is the rear toe +3 degree in total does that mean +1.5degree on each rear wheel?
2. The rear camber link position used in the setup is 1A but when in that position the links do not adjust short enough to get the camber the setup calls for Do you need shorter links to use these positions?
3.The setup calls for "silver" ball studs do these studs have longer threads or is the neck of the ball stud itself longer
4.last in the setup it calls for arm mount shims in millimeters but the manual says they represent different degrees. Is it a typo on the setup sheet or should i measure the shims and go with what the setup says ?
Which arm mount shims that are used in this setup
ADDED thought maybe i am confusing arm mount shims with FWD or RWD mount shims or are they the same thing?
What are the RWD and FWD mount shims?
slicendice is offline
Old 01-09-2011, 03:40 PM
  #1398
mugenize1's Avatar
Originally Posted by JeremyP
Those are Solaris rims.
Can you guys help me find a pair? I can't seem to find them.
mugenize1 is offline
Old 01-09-2011, 03:54 PM
  #1399
Buckaroo's Avatar
Those are the newer spoked rims. Don't think you can get them seperately, they're usually stuffed inside Solaris tires.
Contact info here: Click here. Email them, they'll contact you.
One of their reps also posts here at RC Tech regularly, too. Usually on this thread. Click here.
Google and the "search" button are such wonderful features!
Buckaroo is offline
Old 01-09-2011, 04:05 PM
  #1400
mugenize1's Avatar
I am going to click on what you put up and I did Google it still could not find them
Old 01-09-2011, 04:06 PM
  #1401
Buckaroo's Avatar
Your Google Fu is not strong! Type in "Solaris RC Tires". It'll even show you some links where you can purchase them.
1.Is the rear toe +3 degree in total does that mean +1.5degree on each rear wheel? I'm gonna have to measure that on the set up station, but I think it's PER SIDE. That matches the math when using the degree shims on the set up sheets, too. RWD arm shims (in degrees) MINUS FWD arm shims (in degrees) = rear toe for that side. Be aware the there are -.5 degree and -1 degree rear hubs, too.
2. The rear camber link position used in the setup is 1A but when in that position the links do not adjust short enough to get the camber the setup calls for Do you need shorter links to use these positions? Yes the TC5 links are needed to do just about any but the longest settings
3.The setup calls for "silver" ball studs do these studs have longer threads or is the neck of the ball stud itself longer The silver ball studs have longer shanks than the black ones. I measured it at one point, but I can't for the life of me remember how much longer the silver ones are, but I do remember that in a pinch, you can sub a black with a 1mm spacer for almost the same thing. Threads are the same length, though, in either long or short versions of thread length
Which arm mount shims that are used in this setup Originally, you're supposed to use the plastic arm mount shims, little figure 8 looking things (as shown on the set up sheet in the little box in the middle 'arm mount shims'), but lately people have been using 1 and 2mm aluminum shims. Use whatever you want to get the toe you need. I don't recommend the aluminum spacers until or unless you're good at staying off of the boards
ADDED thought maybe i am confusing arm mount shims with FWD or RWD mount shims or are they the same thing? FWD means the shims between the foreward mount and RWD means the shims in the rear most mount for that end of the car. Thus, the FWD mount on the front is near the bumper and the RWD for the front is to the center of the car. FWD mount for the REAR of the car is to the center, and RWD mount is by the rear of the car
Based on your location, are you planning on racing at (Click here for )Debbies RC World? Plenty of us out there most nights of the week, and every Saturday can help you get set up and running!
Buckaroo is offline
Old 01-09-2011, 05:25 PM
  #1402
rendcool's Avatar
I believe RC market has those ,,,
I was just couldn't get in to their websites ...
and speedtechrc as well ...
http://www.speedtechrc.com/store/ebp...id=856&id=9373
rendcool is offline
Old 01-09-2011, 05:26 PM
  #1403
slicendice's Avatar
well thanks man for some answers that clears a lot up for me
I race down at debbies to i just raced there last saturday first time racing a tc car they are pretty exciting toys ive been there alot lately trying to get practice My name is Drew btw Ill look for ya next time Thanks
Old 01-09-2011, 06:19 PM
  #1404
azz187's Avatar
Originally Posted by JRXS_chris
All wired up and ready to go!
Thought I'd post up a pic of what I've been doing today as well....
Looks nice mate, well done.
azz187 is offline
Old 01-09-2011, 08:00 PM
  #1405
mugenize1's Avatar
Your Google Fu is not strong! Now thats Funny and yes it is not LOL!
Old 01-09-2011, 08:26 PM
  #1406
jdogger1's Avatar
Cool TC6 at the Midwest Grand Slam
Keven Hebert and Joe Trandel dominated the Midwest Grand Slam...
Check out www.rcinsider.com
Jeremy Flint
www.rcinsider.com
jdogger1 is offline
Old 01-09-2011, 08:30 PM
  #1407
in action...
What track is that?
Jeff Cuffs is offline
Old 01-09-2011, 09:02 PM
  #1408
in action...
What track is that?
Old 01-10-2011, 02:32 AM
  #1409
jackdani's Avatar
rome- italy!
jackdani is offline
Old 01-10-2011, 03:45 AM
  #1410
i like to know what rollcenter/springs/oil/piston the DHI Stock winner runs on
the carpet during the weekend
also i am excited of christens low traction carpet setup
thilo-alexander is offline
