Team Associated TC6 Thread >
Like Tree20Likes
Old 02-20-2013, 08:07 PM
  #8806
YoDog's Avatar
Trader Rating: 28 (100%+)
Originally Posted by jha07
Thanks. Am I right to assume you'd need to use a spacer with a fairly large outer diameter to prevent the wheel from wobbling.
There are spacers specifically for TC wheels. It would be best to order a set. TOP and many others make them in different thickness and colors.
Another route would be to get offset hex hubs.
YoDog is offline
Old 02-20-2013, 08:21 PM
  #8807
tonsoffun's Avatar
YoDog,
Are you aware of any dish wheels that have offsets? Seems like they are all 0 offset.
Thanks!
tonsoffun is offline
Old 02-20-2013, 08:24 PM
  #8808
YoDog's Avatar
Originally Posted by ChadB.
Thanks guys for your help. Any idea of how it would take for the whistle to go away?
YoDog: Where can I find your products at?
You can only get them from here or in person at this time. I only make parts in small quantities as I am doing this on the side where I work. I am lucky enough to have access to a machine shop and we primarily make one off prototypes but since I have been learning CNC Machining, my ideas soon become reality then voila! I'm working on getting something more, for the lack of a better term "legit", together but that takes quite a bit of $$$. I've made parts for other cars however since I am now running the TC6.1, I have incentive to make improvements for myself which can trickle down to making multiples of designs that work.
Anyone can feel free to PM me if there is any interest in the servo mounts or if you want to see some of my other projects. Suggestions are always welcome. Another part has been brought to my attention and I will see if it is possible to make and if there is enough interest, I'll make some of them too.
Obviously I won't get rich doing this but if I can help out my fellow racers and in turn help fund my future projects, I'll keep making stuff.
YoDog is offline
Old 02-20-2013, 08:27 PM
  #8809
YoDog's Avatar
Originally Posted by tonsoffun
YoDog,
Thanks!
Most are pretty standard now. you might get lucky with HPI. As I recall, the only wheels that came in different offset were for foam tires. I could be wrong...
YoDog is offline
Old 02-20-2013, 10:10 PM
  #8810
I'm having trouble finding them. You wouldn't happen to have a part number?
jha07 is offline
Old 02-21-2013, 08:23 AM
  #8811
20967's Avatar
I have a question about Arm Mount. I noticed a lot of gap in the Arm Mount hole where the hinge pin is insert in them, this also after fews race.
This gap is more or less higher and different for each supply where I buy.
Is normal or not?
The "PPD Billet" is good, but do not have the choice of new offset and not easy to set up.
Any help is appreciated
20967 is offline
Old 02-21-2013, 08:41 AM
  #8812
YoDog's Avatar
Here are some I found on ebay.
http://www.ebay.com/itm/T-Works-Alum...item338017ba8a
Probably want to search using TC wheel shim. I'm pretty sure that companies like TOP, 3Racing, and spec-R and so on make shims.
YoDog is offline
Old 02-21-2013, 08:47 AM
  #8813
Thanks.
jha07 is offline
Old 02-21-2013, 09:24 AM
  #8814
Tommy R's Avatar
Trader Rating: 21 (100%+)
Last night I noticed some slop in my rear hubs (TC6). It appears that the gap in the control arm is a bit longer than the hub and this allows the hub to move forward/backward within the arm. Are there shims to address this or does it mean the control arm has been "stretched" and needs to be replaced?
Tommy R is offline
Old 02-21-2013, 10:37 AM
  #8815
bertottius's Avatar
Try drilling a hole and putting a set screw in it. Worked like a charm for me.
bertottius is offline
Old 02-21-2013, 11:48 AM
  #8816
Michael@USPN's Avatar
Only for the Reflex chassis. that's why I made my own because the stock TC6.1 wasn't getting any love.
YoDog, thanks for the reply. So how do you like the work you did for the floating servo? Is this something thats not too complicated that we can do too? I have a decent workshop at our other property that we use for wood crafts. Drill press, lathe, etc. Im thinking, can I make the holes need with the drill press? Any pics and help is greatly appreciated bud.
Ty.
Michael@USPN is offline
Old 02-21-2013, 08:06 PM
  #8817
BillPear's Avatar
Ty.
Not sure how much you consider your free time worth but $20 I would buy Yo dogs mount again. very nicely made and anodized to match.
BillPear is offline
Old 02-21-2013, 08:15 PM
  #8818
$20?!! Hollaaaah! Lol. I'm in! Pics please
Old 02-21-2013, 08:24 PM
  #8819
BillPear's Avatar
Yodog has them scattered throughout a few threads a search will release them or PM him. Otherwise you'll have to wait until this weekend when I have some time to take pics of what he sent me. I'd recomend cutting me the middle man out and going straight to THE man.
BillPear is offline
Old 02-21-2013, 08:28 PM
  #8820
Thanks a bunch Bill! Much appreciated.
