Team Associated TC6 Thread >
Like Tree20Likes
Old 11-09-2012, 09:28 AM
  #8011
Sorry - asssuming you mean the most recent one, shown as for carpet from IIC Vegas? Printed that one, but there is another Haynes dated back in May I think that says test session...appreciate the help. Need to gather up goodies for the setup before starting the build.
markg is offline
Old 11-09-2012, 09:38 AM
  #8012
Originally Posted by Shev
Does anyone run the shocks (apart from springs) as per manual? I built my car only last week and have found the shocks really painful to use. I don't mean to be negative, but I had some serious stiction straight away. I'm guessing that the 2 hole pistons are for carpet. Like most others I have read, I found it almost impossible to get zero rebound and there's no bleed holes on the shock caps... I feel like such a noob with these shocks! What's the secret? I love the car, just struggling a little with the suspension. I have bought the rsd options - hopefully that will help. I have drilled holes in the shock caps, replaced pistons, replaced o rings and bladders. Please let me know if I'm missing something. Thanks in advance.
Before you put in the oil, was it easy to push the piston in and out? First make sure there is no binding. To get zero rebound you need to drill a hole in the plastic cap (31329). On the factory team 6.1 there should be a little tiny dot on the inside part of that shock cap to indicate where to drill and drill though it with a 1 mm drill bit. This will allow the bladder to flex without the interference of air pressure behind it. Lastly, when you fill up the oil, you want to push up on the piston. Take your time. You may not want to push up the piston all the way because sometimes air gets in. If it does, just fill a little more and wait for bubbles to go away before putting on the bladder. Also, put on the bladder by rolling it on like how you would roll your finger for a fingerprint. This will push away the oil without replacing it with air while fitting on the shock.
EvetsFidrat is offline
Old 11-09-2012, 09:55 AM
  #8013
Originally Posted by racer_hh
does anybody know what springs are included in the TC6.1 FT kit not the WC.
I think the manual is not correct with green / silver - all look the same only blank silver.
It seems they are a bit soft on my indoor carpet track.
Do you recomment to order the spring set AE offers - to play arround
http://www.teamassociated.com/pictur...88/3988_md.jpg
or is there a better spring set that fits from X-Ray or any other vendor?
I read that the kit came with silver for the front and green for the back but that the green is too soft for carpet use. The 6.1 FT kit now comes with silver all around which is the recomended rate and it was also revised in the manual. I dont recomend the spring set as the difference in rate are too great between all of them. Personally I wouldnt go stiffer than blue in the front and that's the next one above silver. If you want to limit the car's roll in the corners focus on roll centers and droop instead of buying stuff that you wont use.
Old 11-09-2012, 10:13 AM
  #8014
nuttynative's Avatar
I just got a 6.1 and want to run a front gear diff. All the setups online say "silicone ear plugs". What are they talking about? I'll be running asphalt parking lots with a 10.5.
nuttynative is offline
Old 11-09-2012, 10:23 AM
  #8015
briankstan's Avatar
this is what I'm running in mine,
http://www.amazon.com/Prismacolor-Kn...ble+Art+Eraser
alot of people will refer to diff putty as well, it's the same stuff.
I guess that people are using the silicone ear plugs now to get the same effect.
briankstan is offline
Old 11-09-2012, 10:26 AM
  #8016
wtcc's Avatar
They mean that they additionally put ear plugs into the diff so that it becomes more like a soft spool. In your case on a dusty parking lot with this motor I would try without ear plugs. Try different diff oils to find the right one for cornering and acceleration out of a corner.
wtcc is offline
Old 11-09-2012, 10:50 AM
  #8017
I was thinking of 40wt shock oil in the rear and maybe 50 in the front? Or do I need to go heavier in the front?
Old 11-09-2012, 03:12 PM
  #8018
That simply isn't the same...
The idea is to have a diff that is nearly locked like the spool but that is much more forgiving mechanically and also easier to drive. Putty or ear plugs or all of those are comparable to some 50000 wt shock oil if they ever needed that! They do sell actual silicone (liquid) diff oil you could use that has 125000 cst in weight. It is easier to fill up the diff with it because it's still liquid but it's still a bit too loose for most racers. Putty is an extra step stiffer than that.
I've tried 50 wt oil in the front and the car drives nice but it's a bit slower that's all.
Old 11-09-2012, 06:49 PM
  #8019
KC10Chief's Avatar
Originally Posted by SlideMasteR
Yes if you running the std kit CVD's and a spool upfront that is normal, fitting teh DCJ's will eliminate that
Thanks! I figured it was. Here's what I'm going to order. Is this all that I need or am I going to need something else to make it work? It says it's a dual cardan joint bone but that it's two pieces. Is it two pieces per side or is it two pieces total? How many do I need to order?
http://www.reflexracing.net/RSD-TC6-...s-_p_1412.html
KC10Chief is offline
Old 11-09-2012, 07:01 PM
  #8020
Default wow
very nice.. gotta get one.
masterdiver808 is offline
Old 11-09-2012, 07:35 PM
  #8021
geeunit1014's Avatar
Trader Rating: 14 (100%+)
You need these, what you posted is just the bone. You will also need pins and hexes. 5mm is standard
geeunit1014 is offline
Old 11-09-2012, 08:15 PM
  #8022
KC10Chief's Avatar
Thanks for the quick info! That makes a lot more sense. My kit came with pins and hexes. Do I need different ones for some reason? My kit is the world's car, BTW.
Old 11-10-2012, 08:14 AM
  #8023
Shev's Avatar
Thanks mate. Everything you have said is exactly what I had previously done. From drilling the caps to rolling on the bladders to slowly pushing up the pistons. I might try sanding one of the bushing next to the o-ring to try and take some pressure off the shaft. Thanks again for your reply. Much appreciated.
Shev is offline
Old 11-10-2012, 11:30 AM
  #8024
Have you tried coating the O Ring with AE Green Slime? I found this preserves the O Ring and really reduces stiction.
Otherwise you are doing something wrong because these are the best shocks AE ever made and about on par with Tamiya TRF shocks (essentially the same build).
AreCee is offline
Old 11-10-2012, 02:47 PM
  #8025
rosko's Avatar
I had a little issue with my shocks not being completely smooth i shaved my spacer down about half mm green slime to o ring and butter smooth
rosko is offline
