Team Associated TC6 Thread >
Like Tree20Likes
Old 10-02-2012, 10:17 AM
  #7501
wtcc's Avatar
Originally Posted by CristianTabush
Hot bodies will fit, yes.
With the 4mm ones you have to be watchful with the wheels you use. Smaller diameter ones can rub on the A Arm. I typically shave my A-Arms anyways, since the ribs on them will rub under suspension compression with most wheels.
I had this "problem" with the 5mm ones and the TC6.1 arms in combination with the VTEC CPX carpet tires. I could easily solve it by removing a little material from the inside of the rim, but was surprised...
I will try the 4mm hexes nevertheless because my TC6s can never have enough grip. I can even run them narrow on high grip carpet with CPX tires without rolling it.
wtcc is offline
Old 10-02-2012, 04:06 PM
  #7502
Trader Rating: 45 (100%+)
TC6.1 WORLDS CAR
http://www.teamassociated.com/news/l...Worlds_Car_Kit!
transplantlife is offline
Old 10-02-2012, 04:26 PM
  #7503
evochick's Avatar
Well thats good, looks like i only really need to get the lower deck to upgrade my current car, i was thinking about that yesterday when they would release it,
Beth.
evochick is offline
Old 10-02-2012, 04:42 PM
  #7504
Bought my 6.1 a week ago and it's already obsolete
jha07 is offline
Old 10-02-2012, 04:49 PM
  #7505
CristianTabush's Avatar
It isn't, don't worry. It's just the bottom deck. You can always replace it with the new unit and the vertical stud mounts.
CristianTabush is offline
Old 10-02-2012, 05:20 PM
  #7506
I just finished building my 6.1 yesterday. Are the parts listed for the chassis and studs?
BullFrog is offline
Old 10-02-2012, 05:25 PM
  #7507
Monsta's Avatar
Originally Posted by geeunit1014
They are not intended to give longer links, just the vertical ballstud tuning option. V1 is the same length as #s 1/3 on the tower, and V3 is the same as #7. V2 is in between. 2.5mm w/ a short bs is the same height as the #1 hole. Start with what you have been running, and tune from there.
Yes, they do. 5mm hex is the same as the standard hex.
Great, thanks for the info
Monsta is offline
Old 10-02-2012, 06:11 PM
  #7508
evochick's Avatar
Im sure one of the Team will be here soon with the Chassis part number
but studs have been around for a while now
31372 and 31373 for cap A and Cap B,
31374 and 31374 for long and short neck 3.25 ballstuds
31376 and 31377 for new F and R shock towers,
New shock towers are not needed existing ones can be cut down on a bench grinder rather neatly. I had spares so i did this and you cannot tell the difference.
Beth.
evochick is offline
Old 10-02-2012, 06:27 PM
  #7509
Two-speed's Avatar
Trader Rating: 24 (100%+)
So will there be Worlds update kit? I haven't even finished building my 6.1 .
Two-speed is offline
Old 10-02-2012, 06:48 PM
  #7510
arn671's Avatar
Trader Rating: 17 (100%+)
Default WC Chassis
WC chassis is SUUUUUPER narrow at 80mm
arn671 is offline
Old 10-02-2012, 06:55 PM
  #7511
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
http://www.redrc.net/2012/10/associa...orlds-car-kit/
Worlds kit now out
NICE!!!!!
rcpaintinpete is offline
Old 10-02-2012, 07:21 PM
  #7512
evochick's Avatar
did you not see the page full of posts about it ???
evochick is offline
Old 10-02-2012, 07:26 PM
  #7513
JAKE LISZKA's Avatar
Default Vertical Ballstud Bearing Caps
Hey Guys,
I used to run #3 front and rear as my camber link position. Whats the equalivent on the the Vertical Ballstud Bearing Caps and what size shims do I use? Still confused...
JAKE LISZKA is offline
Old 10-02-2012, 07:35 PM
  #7514
evochick's Avatar
#3 on the old towers is equal to V1 (outermost) hole, using a short neck ballstud, and no shims.
Beth.
evochick is offline
Old 10-02-2012, 08:21 PM
  #7515
looks like i just am going to have to get a new chassis plate..
oh dear, how sad, never mind 8)
ed
Edwin Pibal is offline
