Team Associated TC6 Thread >
Like Tree20Likes
Old 09-27-2012, 12:22 PM
  #7471
bertottius's Avatar
Trader Rating: 27 (100%+)
Ok. I'll give it a go. Thanks Rick!
bertottius is offline
Old 09-27-2012, 03:30 PM
  #7472
Will a spur with 8 holes compared to the stock 6 holes work? I know I won't be able to use 3 screws since they won't line up, but 2 screws 180 degrees apart line up. Just wondering if this will cause problems.
jha07 is offline
Old 09-27-2012, 04:00 PM
  #7473
Trader Rating: 45 (100%+)
i used a 67t 48p gear from speedtech with 8 holes. I used 2 mounting screws. Havent had any issues.
RicerX1 is offline
Old 09-27-2012, 05:08 PM
  #7474
jha07 is offline
Old 09-27-2012, 06:12 PM
  #7475
piper48
Guest
Posts: n/a
Originally Posted by Rick Hohwart
Hebert's testing seems to indicate that the stiffer uncut top deck works better on carpet.
Thanks for the help Mr. Hohwart.
Old 09-28-2012, 04:08 PM
  #7476
hiya
i have just got the vertical ball stud parts and am a loss as to what ball studs i should be using to get position 3 on the orignal towers.
help!
ed
Edwin Pibal is offline
Old 09-28-2012, 09:14 PM
  #7477
I just started building my 6.1 and I'm working on the rear diff. The manual is telling me to put shim 31348 on each outdrive, on both the outside of the diff case and on the inside of the diff case. That would require 4 shims.
The problem is I only got 2 shims in Bag B big enough to fit on the outdrives. Looking at the Diff Pin/Shim kit for the TC6 at Tower here:
http://www3.towerhobbies.com/cgi-bin...?&I=LXBUWY&P=7
I got the 4 pins, 5 small shims (on the left), and 2 large shims (on the right). I did not get the medium sized shims (in the middle). Is the manual wrong, or was my kit shorted shims?
rossb is offline
Old 09-28-2012, 09:19 PM
  #7478
your missing the shims dude.
contact who you bought the kit from, and they will sort you out, or just buy the shim kit with the medium shims.
ed
Old 09-28-2012, 10:40 PM
  #7479
Two-speed's Avatar
Trader Rating: 24 (100%+)
Call or email AE customer support at [email protected] . They'll hook you up.
Two-speed is offline
Old 09-29-2012, 01:36 PM
  #7480
AE-Reedy
Originally Posted by Edwin Pibal
hiya
help!
ed
Outside hole black ballstud no shims
Sean Cochran is offline
Old 09-29-2012, 04:43 PM
  #7481
thank you!
ed
Old 09-29-2012, 05:20 PM
  #7482
YoDog's Avatar
Trader Rating: 28 (100%+)
I found that if you open all the bags and sort through all the parts and organize them you may find what you need in a different bag. I ran into a similar problem with my TC6 build. Turns out the grouping of the parts don't always make sense.
Or... They are actually missing.
YoDog is offline
Old 09-30-2012, 01:26 AM
  #7483
Hi Sean
which is the ti-nitride version of the black ball stud ?
all good, found it on the associted web site
thank you
ed
Old 09-30-2012, 11:57 AM
  #7484
I finished the build (except the rear diff) and those diff shims are missing. I found what you said to be true for two 31532 screws (3x8mm) used to attach the rear body posts. Those were in bag "H" instead of bag "D".
rossb is offline
Old 09-30-2012, 12:01 PM
  #7485
wtcc's Avatar
Is there any reason why Xray pinions, for example #305932, do not fit a TC6?
wtcc is offline
