Team Associated TC6 Thread >
Like Tree20Likes
Old 09-14-2012, 03:07 PM
  #7411
RussF's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Fjeld
Did try the high diff roll center to day. It did realy calm the car down did realy like it
Forgive my ignorance, Im stuck back on page 450 trying to read up to this point and figure out what the deal is with roll center. But I have to ask, what did you do to "try a high diff roll center"?
Assuming I have a stock kit setup on my TC6 or 6.1 and I want to try what you did what would I be changing exactly?
RussF is offline
Old 09-14-2012, 03:37 PM
  #7412
Fjeld's Avatar
Turn the diff holders so the diff and spool are at highest point in the car, you will then get a higher roll senter.
Fjeld is offline
Old 09-14-2012, 06:41 PM
  #7413
BigBrute_347's Avatar
Default Body Size
This seems like a dumb question but does this chassis use 190 mm or 200 mm bodies? Which size fits better? Thanks.
BigBrute_347 is offline
Old 09-14-2012, 06:43 PM
  #7414
bhambrent's Avatar
190mm
bhambrent is offline
Old 09-14-2012, 07:26 PM
  #7415
Lost Aggresiva's Avatar
Originally Posted by Rick Hohwart
It should work on carpet although some minor tuning will surely be required. Keven H is testing Carpet this weekend using the high roll center setup so we should have more news next week.
Any updates on Kevin's testing? Curious to see where he went with his setup.
Bill D.
Lost Aggresiva is offline
Old 09-15-2012, 08:38 AM
  #7416
rosko's Avatar
Started to build my tc6.1 and two of my shocks are not threaded right on the bottom where the oring goes
rosko is offline
Old 09-15-2012, 11:38 AM
  #7417
Hi Rick,
When i saw your car for the nats, it seems like you have special caps on your schocks ?
I think this is off road caps.
Can you explain this new setup ?
Regards
fredB is offline
Old 09-15-2012, 06:15 PM
  #7418
Originally Posted by ammdrew
MattDub is offline
Old 09-16-2012, 08:44 AM
  #7419
S_fender's Avatar
Originally Posted by fredB
Hi Rick,
Regards
Hi Fred, Yes Off road caps AND Off road shocks.
Seb
S_fender is offline
Old 09-16-2012, 09:53 AM
  #7420
CristianTabush's Avatar
I believe those were just TC5 Shocks, not actual offroad units. The TC5 Shocks are able to use the Off-road, emulsion style shock caps.
CristianTabush is offline
Old 09-16-2012, 11:29 AM
  #7421
Suspended
Anyone have a good set for 17.5 blinky on a medium/high bite carpet track? This is my first indoor season and I'm a little lost.
Thanks in advance. Please PM me.
Biggie85 is offline
Old 09-16-2012, 01:11 PM
  #7422
mtbboy's Avatar
http://www.teamassociated.com/setupsheets/TC6.1/
http://www.reflexracing.net/RSD6-Inf...age_ep_55.html
mtbboy is offline
Old 09-16-2012, 08:59 PM
  #7423
rosko's Avatar
Any video of 2012 onroad nats at leisure hour anywhere tryibg to find footage of mod tc footage
rosko is offline
Old 09-17-2012, 08:33 AM
  #7424
Rick Hohwart's Avatar
Hi Rick,
Regards
Seb
I wanted to try emulsion style shocks (no bladder, air mixes with oil) and the easiest way to do this is to use older TC5 shocks that have the same thread as the off-road shocks. This way I could install the off-road shock caps with the bleeder screw.
Some drivers have tried to turn the standard TC6 shocks in emulsion style but the reliability has not been good. The TC5 shock is the easiest way to test the concept.
Emulsion shocks have been used on and off by other teams so I wanted to see how they compare. In my brief time using them, I think the emulsion shocks give you more traction. However I had some problems with the shocks I tested and did not have the right internal parts to try and fix them so I went back to bladder shocks which worked very well too.
It is too early to tell if emulsion shocks are the way to go. Perhaps they can be a tuning option. But for now I will continue to test them and see if they are actually better.
Rick Hohwart is offline
Old 09-18-2012, 10:40 AM
  #7425
RussF's Avatar
What length front and rear camber links do I need to use the 1-6 holes on the shock towers of a TC6?
A part number would be most helpfull.
RussF is offline
