Team Associated TC6 Thread >
Like Tree20Likes
Old 08-19-2012, 11:51 PM
  #7321
Originally Posted by Odin544
ok one more question. I remember a while ago (last winter) someone asked how to protect the chassis from the droop screw which will eventually dig into the chassis. Someone posted a pic of their solution. They had found some small metal discs that I thought were adhesive backed. I've been searching this thread for about 3 hours with no luck. Cant think of a good search term and browsing every page is taking a looong time!
http://www.spec-r.com/default/index....roducts_id=306
Haven't tried 'em.
-Mike
grippgoat is offline
Old 08-19-2012, 11:58 PM
  #7322
Odin544's Avatar
Trader Rating: 93 (100%+)
Awesome thank you!
Odin544 is offline
Old 08-20-2012, 08:41 AM
  #7323
Fjeld's Avatar
Originally Posted by gom
I am trying to get to 7 FDR here using 64 pitch gears. I tried 116 spur but it's too big. I also tried a 96 spur and that's too small. I don't have anything in between so I need to buy one. Just not sure what size will produce 7 FDR that'll also let the spur and pinion mash freely.
If anyone is running approx. 7 FDR please let me know your spur and pinion combo. thanks.
Try the gear sheet in the manual
Fjeld is offline
Old 08-20-2012, 10:03 AM
  #7324
Madulla's Avatar
33/115 is what I use
Madulla is offline
Old 08-20-2012, 02:58 PM
  #7325
http://abram.eu.org/gear_tc6.php
try this
M.Abramowicz is offline
Old 08-20-2012, 04:26 PM
  #7326
racer x 1's Avatar
Trader Rating: 27 (100%+)
Any body have any suggestions for gearing 13.5 blinky duo 3.5 with tekin rs.
Im mainly looking for what spur to run 64p
racer x 1 is offline
Old 08-20-2012, 06:47 PM
  #7327
Maybell's Avatar
I ran 96x48 at the Reedy race with a sonic 13.5...That might be a little tall for that duo motor though...
Maybell is offline
Old 08-20-2012, 07:39 PM
  #7328
gom
got it. thanks guys. especially for the gear chart.
gom is offline
Old 08-21-2012, 10:32 AM
  #7329
AJSanDiego's Avatar
Just want to say thanks for the setup tips guys. Switched to 0B and softer springs in the back (AE Grn) and did much better. Realized that when saucing tires you really need to give it more than 5-10 minutes to set in. After tires got warm car handled great. Well - at least until I got hacked so hard the screw holding the steering bellcrank came loose. With blue loctite to boot. I thought only the off-road guys hacked...
AJSanDiego is offline
Old 08-21-2012, 10:12 PM
  #7330
Team Grid RC's Avatar
Originally Posted by Rick Hohwart
I'm not sure what he uses but 2-3mm is the range. I use 3mm.
We are also using 3m spacers as well.
To make easy access to the shocks and never have to wait for thread locker to cure, we use nylon screws. Torque them down lightly and they never come loose.
Team Grid RC is offline
Old 08-23-2012, 06:32 AM
  #7331
evochick's Avatar
This thread needs some TC6.1 action shots
This is from our state based Club Challenge Cup series last weekend.
I qualified 3rd in Blinky for the A Main, but got overtaken by the 2 quicker cars behind me and finished 5th for the day and 4th overall for the series for the year.
All photos by Leigh Nelson Copyright 2012 All rights reserved
Beth
evochick is offline
Old 08-24-2012, 10:03 AM
  #7332
On carpet what is everyone running for a wheel base.
losi888 is offline
Old 08-24-2012, 10:06 AM
  #7333
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Stock spacing
geeunit1014 is offline
Old 08-24-2012, 10:53 AM
  #7334
Is that 1mm shim in front (in front of a arm) and 1mm shim in the rear (on the back side of a arm).
losi888 is offline
Old 08-24-2012, 04:45 PM
  #7335
justchris's Avatar
Beth
Really Really good photos.!!!!!!!!!!!!!!!!!!!
justchris is offline
