Team Associated TC6 Thread >
Like Tree20Likes
Old 05-20-2012, 02:43 AM
  #6781
Geberit's Avatar
Tire rubbing Levanen TC6.1!
Attached Thumbnails Team Associated TC6 Thread-sun-levanentc6-1.jpg   Team Associated TC6 Thread-sun-levanentc6-2.jpg   Team Associated TC6 Thread-sun-levanentc6-5.jpg
Geberit is offline
Old 05-20-2012, 07:13 AM
  #6782
CristianTabush's Avatar
Exclamation
On the tire rubbing, I noticed this a while back and posted about this although nobody seemed to have much input. I did notice that some wheels have a smaller diameter than others so it can be worse. It is especially bad under suspension compression. I have been considering going back to tc6 arms in the rear at least, which actually should aid with traction as they are a bit shorter.
CristianTabush is offline
Old 05-20-2012, 07:20 AM
  #6783
Wattsup23's Avatar
Trader Rating: 29 (97%+)
That looks like it might be from the rim being the wrong offset.
Wattsup23 is offline
Old 05-20-2012, 07:57 AM
  #6784
Geberit's Avatar
The tires are RIDE 32 out door with red marking.
Geberit is offline
Old 05-20-2012, 06:16 PM
  #6785
It's not from the wrong offset.
I tested today with some Sweep OG , and with Solaris wheels as well. I had really bad rubbing from the wheel flexing in the front
Given it was about 95 degrees F and the track was huge (18.5-19.0 second laps with a 4.0 turn motor) with medium high grip, so this made it worse, but I did have to trim the front arms quite a bit. Not that much of a hassle, but it is something to watch for when running faster motors.
Old 05-20-2012, 09:50 PM
  #6786
R Doyel's Avatar
Trader Rating: 14 (100%+)
Hoping to see some of you out here in California for the Reedy. Today was a warm-up race. A great showing for Associated, with several team drivers attending.
This is only the 3rd time out with the 6.1 and I love this car! A big thanks is due for The Albano's - Joe, and Eric - Helping me get the car working well. Support like this at a local track is why I switched to Associated.
IMG_9734 (2) by 51 wheels, on Flickr
R Doyel is offline
Old 05-21-2012, 04:42 AM
  #6787
Hi,
I'm actually using offset arm mount at the front of the car. If I use the standard one, but with 1.5mm shim, I will have move steering at corner entry?
nicoo2k4 is offline
Old 05-21-2012, 06:06 AM
  #6788
daleburr's Avatar
Originally Posted by WD40
Can anyone post a good setup for medium grip concrete track for the tc6.1? It might be in this thread but I don't have time to look through 400 pages of posts. It will be a VTA and 17.5 class for reference.
Never raced on concrete, but if the grip levels are medium I'd think any of the medium-grip Asphalt setups will be fine. Try one of Andrew Abbotts off the Associated site, or Olly Jefferies off the CML site.
daleburr is offline
Old 05-21-2012, 08:09 AM
  #6789
Big Features's Avatar
Tire choice will be a big factor when racing on concrete. The Aloha Tower race in Hawaii is on concrete and I really didnt change my car at all. I did go up to a harder tire (40s VS 36s) because the concrete was more abraisve.
Mike
Big Features is offline
Old 05-21-2012, 08:32 AM
  #6790
rbcts's Avatar
Trader Rating: 34 (100%+)
Hi All,
Just ordered the kit. First on road car so I'm pretty excited. Ive been racing offroad for a while now. Just wanted to know what spare parts I should be carrying around in my bag that are known to break/wear quickly.
Thanks!
rbcts is offline
Old 05-21-2012, 11:05 AM
  #6791
Depends how hard you hit the wall
I actually have some hubs, suspension parts and maintenance parts like shocks as spare parts.
Oh yeah. Take some spool outdrives as a spare, they brake first on a crash
dennisV is offline
Old 05-21-2012, 11:20 AM
  #6792
rbcts's Avatar
Yea for sure. Thanks!
rbcts is offline
Old 05-21-2012, 11:25 AM
  #6793
AJSanDiego's Avatar
Originally Posted by chevtech23
Yes arm mount shims, FWD(forward) RWD(rearward) for that end of the car, you would run the same in the front forward and front rearward, and possibly different ones in FWD and RWD in the rear to adjust rear toe, along with a combination of offset and standard arm mounts.
I use these for the shims, Associated #3617
http://www.amainhobbies.com/product_...-Bulkhead-Shim
Hopefully this is a more helpful answer than "RTFM"
Thanks. And for the link too. I went ahead and went with my assumption. Went with the stock recommendations and except for RWD rear - put the 2* to start with (what I think is) 2* toe when combining the 0 offset rear arm mount and the shim. Should be dropping my electronics in today. Can't wait.
AJSanDiego is offline
Old 05-21-2012, 11:28 AM
  #6794
AJSanDiego's Avatar
Thanks for that! Went through and grabbed a bunch of spares. Got blades but not the out drives. Darn - guess I gotta place another order. Should prolly add a couple things - since I'm there and all...
Old 05-21-2012, 01:07 PM
  #6795
jhautz's Avatar
Trader Rating: 86 (100%+)
Originally Posted by rbcts
Hi All,
Thanks!
C-hubs, blades for the dog bones, plastic spool out drives, are the things I have broken in my first 2 race days. I also somehow chipped one of the pullys for the belt on the center spur gear assembly. Not exactly sure how, it may just be one of those freak things. Other items that seem like they would be a good idea to have are: shock parts(shafts,plastic caps, o-rings), Optional springs, optional sway bars, gear diff for the front, spare bearing, rear hubs, a set of arms and maybe some steering knuckles and body posts.
The car is actually pretty solid and durable. The things I did break were from stupid hits that deserved something breaking. I pretty much did all of the damage on my first day out. I didn't break a single thing on the 2nd race day. Less hitting the boards, and when I did it was less severe hits.
So far I think this is a great little car.
jhautz is offline
