Team Associated TC6 Thread >
Like Tree20Likes
Old 10-19-2010, 09:45 AM
  #436
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Josh Hohnstein
Can't do any photos right now. How about a brief description.
Steering system......way more linear than before, the longer arm on the servo side of the steering rack made a huge difference. And all the adj. are pretty cool, 6 different forward and back, wide or narrow at the rack, 2 holes at the steering knuckle.
The motor is in........way in. I ran 12lb springs and the car still did not rub.
Hinge pin mount screws go in from the outside now, and there is an extra position for hinge pin height.
The servo mount holes are sliders so you have the option of moving the servo front to back.
Shocks are so easy to build.
Motor mount plate has 3 screw holes instesd of 2.......side, side and bottom.
The plate is raised off the chassis and secured down in the exact center as to not tweek the car at all.
whats the LOWEST FDR that you can achieve with the TC6? (non boosted 17.5 and 21.5 are popular here.)
Hebiki is offline
Old 10-19-2010, 12:02 PM
  #437
Aahj's Avatar
Thanks for all the updates guys! Can't wait to get mine.
I have a quick question, are the body posts exactly the same on a TC5 as compared to the TC6? Just wondering if I need to purchase another body.
Thanks!
AJ
Aahj is offline
Old 10-19-2010, 12:21 PM
  #438
twk-b's Avatar
Thanks!
AJ
Keven said a couple pages back they are at most a mm out or so... so with a little fiddling old bodies should work ok...
-b
twk-b is offline
Old 10-19-2010, 01:48 PM
  #439
Trader Rating: 3 (80%+)
Thanks!
AJ
Perfect fit on mine.
Josh Hohnstein is offline
Old 10-19-2010, 01:52 PM
  #440
ive had mine on order since the worlds!
all these changes, its like being a kid in a candy shop!
anyone know when the manual will be online so i can download it and read it 100 times before the kit arrives ?
Ed
Edwin Pibal is offline
Old 10-20-2010, 08:38 AM
  #441
JuhoL's Avatar
The internal ratio is 2.0 and on my car I run 114/26 gears. The motor should stay in the same position if the total combined pinion size and spur size stays the same. So for example with 40 pinion and 100 spur you would get a ratio of 5.0 and 50 pinion 90 spur 3.6. Not sure what gear sizes in general are available as I never run stock but you should be able to get it low enough.
JuhoL is offline
Old 10-20-2010, 08:51 AM
  #442
AM03GT's Avatar
I would think it's about the same gear space for a TC5. I'll verify it tonight but I think the lowest I have gears for is 2.826 and it fits.
AM03GT is offline
Old 10-20-2010, 10:09 AM
  #443
Hebiki's Avatar
thank you!
Hebiki is offline
Old 10-20-2010, 03:05 PM
  #444
Bubblehead's Avatar
I know this question has been asked, but what is the new release date?
Bubblehead is offline
Old 10-20-2010, 05:02 PM
  #445
DaveW's Avatar
Not soon enough Ron...
DaveW is offline
Old 10-20-2010, 05:55 PM
  #446
AM03GT's Avatar
just checked on my TC5 65/46 48P fits... 2.83 FDR...
AM03GT is offline
Old 10-20-2010, 11:58 PM
  #447
HB Moose's Avatar
I ask the Engineer in charge tonight. The shipping container should be loading this week. Figure about 3 weeks until it hits the stores.
HB Moose is offline
Old 10-21-2010, 10:31 AM
  #448
wtcc's Avatar
As if I knew it! The date was pushed again! Now TT says it will arrive on 28.10.2010
wtcc is offline
Old 10-21-2010, 12:25 PM
  #449
jeppesen's Avatar
If Juho can confirm it is ok, i can put the pictures up here that i took off his car, at last weekends ETS race, its only mobile phone pictures.
jeppesen is offline
Old 10-21-2010, 01:29 PM
  #450
Bubblehead's Avatar
Thanks, I think I can wait that long.
