Team Associated TC6 Thread >
Like Tree20Likes
Old 10-26-2011, 10:02 AM
  #4336
Suspended
Hi James
A Starting point in gearing as far as what to buy,
Originally Posted by JamesL_71
What exactly are you looking for? A starting point in regards to gearing and setup? Or a starting point in regards to what electronics/motor/ESC to buy?
epowr_Racing is offline
Old 10-26-2011, 10:28 AM
  #4337
Would anyone not want to run sway bars or run a single one on a med to high bite technical asphalt track???
Just wondering...
zzztech is offline
Old 10-26-2011, 11:06 AM
  #4338
Are you using the off-road t-nut to secure the thrust bolt?
No I'm using the one that came with the car. Can I use the off-road t-nut?
f1o7x9 is offline
Old 10-26-2011, 12:36 PM
  #4339
cwoods34's Avatar
I never had issues with the stock t-nut with ANY motor.....
With regards to the swaybars...... I think it depends on what motor you are running. I've only wanted swaybars on fast flowing tracks.......
PM's replied also......
cwoods34 is offline
Old 10-26-2011, 12:57 PM
  #4340
Scottmisfits's Avatar
Really, there is nothing wrong with the stock T Nut in the kit. But it is very easy to over tighten. Why they felt the need to use a different one when the offroad one is better, I'm not sure. But just switching to the offroad t nut won't solve the issues. Not just that alone. I think you may just need a new screw and nut. It just might be worn. But for the extra little $, just change the whole thing. It's only $1 more or something.
Scottmisfits is offline
Old 10-26-2011, 01:03 PM
  #4341
Just wondering...
This is the only time I take the swaybars off.
Lionel S is offline
Old 10-26-2011, 01:05 PM
  #4342
bshookup's Avatar
Trader Rating: 21 (100%+)
Originally Posted by f1o7x9
I need some help with my spool. So I was doing 17.5 and my spool work really good now I'm going to mod and my spool gets lose all the time and I tightened it really good . I even try red threadlock. I can really use some help. thank you
You may want to check that the thrust assembly is working correctly. I and others had problems with the TC5 slipper spool coming loose before we realized that we needed to put thrust bearings in it.
bshookup is offline
Old 10-26-2011, 01:13 PM
  #4343
cwoods34's Avatar
Perhaps the slipper pads are dirty/worn/glazing over. That'd cause them to slip no matter how tight you have it. This could possibly be causing the screw to back out..... just speculation though, I haven't experienced that myself.
cwoods34 is offline
Old 10-26-2011, 01:19 PM
  #4344
Originally Posted by epowr_Racing
Hi James
For non-boosted 17.5, I would start around a 4.0 FDR. Using 64p gears, I would shoot for 48/96.
JamesL_71 is offline
Old 10-26-2011, 03:22 PM
  #4345
You could make little wet and dry "washers" to replace the spool pads and glue them in place, change bolt and nut for sure and even use loctite before assembly.
Should not move now....
There is a new locked spool coming out in November too.
And YES a check of thrustrace is a must
olly986 is offline
Old 10-26-2011, 03:38 PM
  #4346
Thanks for all the help I try it
f1o7x9 is offline
Old 10-27-2011, 12:41 AM
  #4347
StickyFingaz's Avatar
Trader Rating: 17 (90%+)
FYI, I broke two sets of the Spec-R gear diffs on the first and second battery pack with my 4.5 motor. Sanded the back of the spider gears and everything... Needless to say I can't wait for the AE units to start shipping.
StickyFingaz is offline
Old 10-27-2011, 04:20 AM
  #4348
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
You broke the bevel gears?This steel hpi gears should work I have some coming to try out just in case
http://www3.towerhobbies.com/cgi-bin...?&I=LXMAA1&P=7
Marcos.J is offline
Old 10-27-2011, 04:27 AM
  #4349
You should have a good look at this, there is a problem, to break one gear could happen, but two...it is very strange.
olly986 is offline
Old 10-27-2011, 05:19 AM
  #4350
cwoods34's Avatar
I put 3-4 packs with a 3.5 on mine and they held up fine.....
I only changed back to a front spool for setup purposes.
cwoods34 is offline
