Team Associated TC6 Thread >
Like Tree20Likes
Old 04-14-2011, 12:29 PM
  #2251
Trader Rating: 56 (98%+)
Originally Posted by Rick Hohwart
In development.
"In Development" is usually what I get from software engineers on things I want that I'll never see, but they dont want to tell me officially 'no' in writing. lol
Hope an Associated gear diff shows up before summer is out.
jhhack is offline
Old 04-14-2011, 06:07 PM
  #2252
Thanks Rick for the response, looking for the option parts to start rolling out for TC6 even tho the car is good now, only can get better.
WEEZY is offline
Old 04-14-2011, 07:14 PM
  #2253
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Default TC6 spurs?
Looking to get a 3.6 FDR and need an aftermarket spur/pinion combo. What are people recommending?
I'm looking at the spurs offered on Speedtech R/C. Kimbrough, RW Racing, Speedtech, and Xenon spurs are the ones I'm interested in. Number of teeth on the spur and pinion would be helpful.
Thanks!
tr1kstanc3 is offline
Old 04-14-2011, 08:11 PM
  #2254
Maybell's Avatar
Thanks!
If you can find a 49 tooth pinion, a Kimbrough 88 will get you a 3.59. For a 3.6 to fit the motor mount, I think you will need a spur in the 88-92 range.
Maybell is offline
Old 04-14-2011, 08:56 PM
  #2255
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Thanks!
90/50
geeunit1014 is offline
Old 04-14-2011, 09:45 PM
  #2256
VAzRACER's Avatar
Trader Rating: 17 (100%+)
Originally Posted by geeunit1014
90/50
Yep, 90/50 is the closest setup I could find to fit with the adjustment available on the motor mount. It's exactly 3.60 fdr. Tried 85/47 for 3.62 and it didnt fit.
VAzRACER is offline
Old 04-14-2011, 09:54 PM
  #2257
Trader Rating: 88 (100%+)
Or you could use an Associated 69T spur and a 38/39 pinion if you want to stick to 48 pitch. HKSRC carries the 3racing pinions which go up above 40 in 48 pitch. I'm running the 69/38 on my TC6
tcdrvr2 is offline
Old 04-15-2011, 06:23 AM
  #2258
tr1kstanc3's Avatar
Trying to visualize why 85/47 wouldn't work.. what's happening on the motor mount that does not allow for this?
Old 04-15-2011, 06:42 AM
  #2259
mr fit's Avatar
Does anyone know if exotek is coming out with a tc6 chassis
mr fit is offline
Old 04-15-2011, 07:13 AM
  #2260
Because they will not mesh?
No space for them, you can't move motor for this dimensions.
Check my gear chart!
m.
http://abram.eu.org/gear_tc6.php
M.Abramowicz is offline
Old 04-15-2011, 08:24 AM
  #2261
tr1kstanc3's Avatar
m.
Excellent chart. Thanks!
Old 04-15-2011, 10:22 AM
  #2262
CristianTabush's Avatar
Is that you I see on the TC6 Thread Joe? I see Mike G and Matt hanging out in here... Another convert perhaps?
On another note, we have been able to fit all the way up to a 39-40 tooth pinion with a 78 tooth, 48P spur. I have found this to be the most versatile size if running boosted and non boosted 17.5. You can get the ratios on both ends without changing a spur. I guess the equivalent in 64P would probably work well too.
Rick H. I stand corrected, looking at the pictures well, I now see the difference.
CristianTabush is offline
Old 04-15-2011, 10:46 AM
  #2263
wtcc's Avatar
Äh, what? Why should they? The actual chassis is Lipo and asphalt already...
wtcc is offline
Old 04-15-2011, 11:13 AM
  #2264
jackdani's Avatar
Originally Posted by WEEZY
What shock tower is juho using for support in the back for the body?
which white springs are these??
jackdani is offline
Old 04-15-2011, 11:28 AM
  #2265
roger999's Avatar
Yokomo
roger999 is offline
